smoking
Old Sep 16, 2009 | 02:31 PM
B15Risk's Avatar
B15Risk
Default smoking
just a quick question does anyone know what would be the problem with my car start it up its fine let it sit there and it starts blowing blue drive it and it clears then sit it up running again and about 3 or 4 mins it smokes again any ideas cheers
Old Sep 18, 2009 | 07:46 AM
stefaan's Avatar
stefaan
When it starts smoking blue..does it also starts to run very rough??
Does it stongly smells like petrol?
I ask you this, because i had a simillar problem a few months ago.
The reason was a broken membrane in the fuel regulator. This causes an overfueling when the car runs on idle - due to the vacuum, petrol was sucked through the vacuum pipe of the fuel regulator into the intake manifold.
Sorry for my bad english - i am Austrian
Old Sep 19, 2009 | 08:22 AM
big mac's Avatar
big mac
sounds like turbo imo
Old Sep 19, 2009 | 08:30 AM
cozzy940's Avatar
cozzy940
stem seals?
Old Sep 19, 2009 | 04:05 PM
B15Risk's Avatar
B15Risk
cheers for your input guys will prob pull it apart and have a look at turbo and other parts
Old Sep 21, 2009 | 05:27 PM
j6kyt's Avatar
j6kyt
turbo
Old Sep 21, 2009 | 06:04 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
turbo seals.
when on boost the bosot pressure and increased exhaust gas will keep the oil out of the turbo housing, when idling the oil pressure is greater than the back pressure so a little bit makes its way through.
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
