Where can i find an adaptor plate so i can fit cossie discs and calipers to my RST?
Sep 13, 2009 | 08:06 PM
Where can i find them guys?
Thanks,
Shep.
Sep 13, 2009 | 08:09 PM
Sep 13, 2009 | 08:30 PM
I presume you need them for rear disc conversion?
oddkidd creations come with countersunk bolts so no grinding boltheads away to clear the hub
Sep 13, 2009 | 08:36 PM
no its the front brakes. Cant find anything on eBay. The guy who was fitting them for me said there to big to just fit straight on. He said i need an adaptor plate like what you need when you fit the mondeo discs on.
Sep 13, 2009 | 08:37 PM
You don't need them for the front if you fit 4x4 calipers/2wd discs. A washer is all that's required to space the caliper out slightly.
Sep 13, 2009 | 08:42 PM
Sep 13, 2009 | 08:53 PM
on the front common conversion is cossie 4x4 calipers and 2wd discs, mine just needed a bit of filing to the caliper carriers, some people use a washer to space the disc centrally (mine didn't need this)
Sep 13, 2009 | 09:49 PM
yeh i have 4x4 calipers and sure there 2wd discs. The guy i put them off just said i need 4 x 1mm washers to fit them to the RST.
Sep 13, 2009 | 10:03 PM
thats 1 washer per bolt, sounds correct, but as I said, when I done mine no washers were needed
Sep 14, 2009 | 04:21 PM
Have a look at the sticky at the top of the page mate tells you everything you need to know
mark.
Sep 14, 2009 | 08:15 PM
As you were told by the guy who sold em to you, 4x1mm penny washers is all that's required to space the disc out. Worked perfect on mine.
Billy_RS
16
Oct 11, 2025 09:41 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
orionguy
Aug 6, 2015 07:36 AM
dlwarrior
Aug 5, 2015 10:19 AM
