gotech mini x list of parts
Old Sep 11, 2009 | 09:34 AM
CF20's Avatar
CF20
RS
Default gotech mini x list of parts
i have a gotech mini x ecu can someone tell me a full list of parts that i need to get for to fit it inc idle speed control ?
Old Sep 11, 2009 | 10:08 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If you mean your converting to EFI and want to know what parts you need then look at the sticky at the top of the page?!
Otherwise a little more info please?
Karlos
Old Sep 11, 2009 | 10:20 AM
CF20's Avatar
CF20
RS
gotech mini x runs off the s2 dissy i know i need efi injectors and a modified inlet / fuel rail
i need to know if im using mfi inlet running efi injectors which throttle body is best to use the mini x as the ability to run a idle speed valve and again which one is the best to use ?
Old Sep 18, 2009 | 04:51 PM
crazycage's Avatar
crazycage
why not just ring jamie @ jamsport up and get the proper advice.
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
jonnyenglish
Sep 21, 2015 07:31 AM
Fudgey
Sep 17, 2015 01:06 PM
