Removing Cosworth Kidney box
Old Sep 8, 2009 | 09:24 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Default Removing Cosworth Kidney box
Can you remove the standard kidney box oil breather without removing the inlet manifold?
Just as important - can you refit it (or a proper breather system) without removing the inlet manifold?
Just want to know how much back-breaking's involved.
Old Sep 8, 2009 | 09:38 AM
john_p_b's Avatar
john_p_b
yeah it'll come out they don't go in that deep really. Twist and pull.
Old Sep 8, 2009 | 09:46 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Yes - a tight squeeze to remove with the engine in the car though - a lever/screwdriver under the box and lever it off
Give it a good clean out while it is out of the car aswell, it will be full of emulsified oil/mayo due to the condensation that forms when the engine is cooling down
Old Sep 8, 2009 | 09:50 AM
ally7th's Avatar
ally7th
woodhouse motorsport
is it not just this bit you remove to fit bailey etc breather kits?
so you are left with this bit-
Old Sep 8, 2009 | 09:57 AM
Graceland's Avatar
Graceland
Team HOTHOT!
That is correct - you remove the gauze flame trap and leave the big kidney box - the kidney box is essentially a breather/seperator (on 4x4 it is) with a crankcase breather and oil return and then the top port goes to the air box + inlet manifold via the flame trap on a standard setup. On an uprated setup, you remove the flame trap, the inlet manifold valve and airbox pipe and fit a 19mm internal diameter pipe from the kidney box to the aftermarket breather tank
A bit like this:
Old Sep 8, 2009 | 10:12 AM
cozmeister's Avatar
cozmeister
More boost Igor!
I've got a new kidney box to put in instead of my original which is probably blocked and gummed up. So the kidney box remains, even with a aftermarket breather system?
Old Sep 8, 2009 | 10:21 AM
Graceland's Avatar
Graceland
Team HOTHOT!
My kidney box is still there - it serves a purpose and works so it stays
CLIVE
Oct 2, 2015 12:58 PM
matman
Sep 9, 2015 05:45 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
