L8 Board???
Do L8 ECU's come with a piggy back board or is it an bolt on extra? Doe's the chip fit straight onto the board or doe's it need the piggy back board?
cheers
cheers
yes they have a std ford board.
and some are chaged to pectel boards, so you need to know what you have and what method of encryption your chip is written for
ie, if you put s a std ford encrypted chip into a pectel board it wont work, and vice versa
yes they have a std ford board. Pal
and some are chaged to pectel boards, so you need to know what you have and what method of encryption your chip is written for Pal
ie, if you put s a std ford encrypted chip into a pectel board it wont work, and vice versa Pal
I actually have one i'd part with, only thing is it needs a new blue connector as some gimp (me) broke a couple of pins off in a fit of mongness one day
If you can get another connector, very easy, it just pushes on over the ribbon cable, no tools required.
I've kept meaning to get a run to somewhere like maplins to see if they've got them in stock, keep forgetting though!
DixieTheKid
11
Jun 6, 2020 11:20 AM
Escortdriver1
Aug 19, 2015 09:02 PM
