Throttle Bodies
Old Sep 2, 2009 | 08:48 PM
1980orangeman's Avatar
1980orangeman
Default Throttle Bodies
Can anyone help. I'm after a throttle bodie to fit mk1 1.6 zetec 2000 focus. I want to improve the acceleration and understand that the inlet hole being bigger will help this. What can I use for best and easiest fit without modifying attachment. Also I have been told that the ECU can reject the part and the engine may not start any suggestions anyone??
Old Sep 2, 2009 | 09:20 PM
JonnyBravo's Avatar
JonnyBravo
You will need a complete setup inc ecu and then having it mapped.
Jenvey throttle bodies on Omex management is a kit I recal seeing for those engines.
I'll do some looking about and post the info on here for you
Old Sep 3, 2009 | 12:58 AM
Gaz 88's Avatar
Gaz 88
just throw the st170 lump in it for under a grand!!
Old Sep 3, 2009 | 10:06 AM
A larger tb will only give you an advantage IF it is a restriction to start with, if going aftermarket or substantially different from std then management will need to be sorted as well.
Just simply putting on a tb from a bigger model if it fits is very unlikely to prevent it starting, but won't do any good, the ecu doesn't "reject" things as it doesn't know if it powering a mini or a jumbo jet, ie it doesn't know what it's attached to.
As a basic rule if the tb was a restriction enlarging would slow down air speed and lose low speed crispness/running.
Old Sep 15, 2009 | 03:43 PM
MisiekT_PL's Avatar
MisiekT_PL
my friend put a stock 2.0 TB on his 1.6 and it works fine without ECU remapping... huge difference in throttle response and revving according to him...
considering how easy and cheap this mod is, worth doing
PS. AFAIR he just needed to make a new gasket, modify accelerator line (if that's how it's called in English) and reset the ECU, other than that P&P
Old Sep 17, 2009 | 03:50 PM
gramsey's Avatar
gramsey
checkout http://www.shawspeed.com/fsigma.htm. they do a range of different kits with or without tb's. Ill be going down that route for mine in the near future
Old Sep 24, 2009 | 02:43 PM
1980orangeman
Thanks for the reply, nice and easy price layout cool web page.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
