Make my car handle!!!
Old Sep 1, 2009 | 10:26 PM
Rob_DOHC's Avatar
Rob_DOHC
Default Make my car handle!!!
Hi there,
The car has Avo front coil overs with i think koni rear shocks and some stiffer lower springs (unknown make). After the car has stopped torque steering all over the place, if at speed becomes (or feels) really unstable..
There is LOADS of neg camber, is there any thing i can do about this? front and back.
Its also on 17's at the moment but going back to the original wheels.
Cheers for all your help
Rob,
Old Sep 1, 2009 | 10:36 PM
RUPERT THE BIG HAIRY BEAR's Avatar
try buying some new suspension thats equal and correct for the car you got
Old Sep 1, 2009 | 10:40 PM
Rob_DOHC's Avatar
Rob_DOHC
Just looked through the paper work and the car has a sport revolution kit, so front coil overs and gas rear shocks. All Avo.
What ever kit it had on would still give neg camber though... depending on how low. Mixing brands wouldn't really matter front to back so long as the spring rates and dampers were chosen well. Are there adjustable bottom arms i can get?
But cheers for the advice
Rob,
Old Sep 1, 2009 | 10:45 PM
what car is it
Old Sep 1, 2009 | 11:18 PM
scoobypete's Avatar
scoobypete
Originally Posted by RUPERT THE BIG HAIRY BEAR
what car is it
as its in the Ford Escort rs turbo section i would say its an escort rs turbo make sense?
Old Sep 1, 2009 | 11:22 PM
oh yeah lol blonde moment dint see that up there
Old Sep 1, 2009 | 11:27 PM
scoobypete's Avatar
scoobypete
lol we all have our moments lol
Old Sep 1, 2009 | 11:42 PM
NUTS RuS's Avatar
NUTS RuS
We have adjustable TCA's available for the front that will pull back in your negative camber, but if your swapping back down to 15's you may be better of waiting until fitted.
After that re check tracking and toe settings.
Rears are a little more expensive to sort out properly, but a cheap bodge is to elongate the hole in the body on the inner wishbone mounting points to pull the wishbone in/out.
Old Sep 2, 2009 | 07:35 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as said, adjustable track control arms.
cost a few quid, but you'll have better handling and save tyres scrubbing on inside edge only.
Old Sep 2, 2009 | 08:32 AM
Antti O's Avatar
Antti O
How much those adjustable tca:sa will cost? I think those are illegal in Finland but still interested.
Old Sep 2, 2009 | 08:48 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
go back to 15's mate, mine was on 17's and drove and handled like a bag of shit so put standard rims back on!!!
Old Sep 2, 2009 | 08:51 AM
matt p's Avatar
matt p
15's - lightweight wheels if you can, pref oz mags
Adjustable TCA'S
Solid bushes throughout
Matching coilovers will help no end!!
Front and rear strut brace.
HTH
Matt
Old Sep 2, 2009 | 10:59 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
check out www.burtonpower.com for a guide price till nuts rus comes online.
Old Sep 2, 2009 | 12:30 PM
teahan's Avatar
teahan
if its all over the place and low, try toeing it in a small ammount, it should help straight line stability. i switched from standard wheels to slightly wider 15" compomitive th's, with a lower offset, the extra width at the rear i felt made the rear more stable when cornering. possible just a confidance thing. i lowered mine on spax adjustable dampers and springs, probably lowered it too much though, i think raising it up will help with crashiness and bump steer. just my two cents.
Old Sep 2, 2009 | 12:53 PM
G420 DEL's Avatar
G420 DEL
a good start would be getting the wheels on you want, then going to get the tracking set up correctly, if you go to a good place you will get a readout of what all 4 wheels are doin then you will have a much better starting place
Old Sep 2, 2009 | 01:48 PM
Antti O's Avatar
Antti O
And i think the worst thing in mk4 escort handling is that crappy feel steering. Too slow and awful in all way.
Old Sep 2, 2009 | 03:32 PM
teahan's Avatar
teahan
steering isn't that bad! try driving a corolla/micra, basically jap rubbish!
more toe out would give a better turn in, and polybush everything!
Old Sep 2, 2009 | 06:01 PM
JesseT's Avatar
JesseT
Lowered cars also usually have far too much rear toe that make the car feel sluggish.
Old Sep 3, 2009 | 12:28 PM
teahan's Avatar
teahan
dragging the back around with you! toe in on the rear will also make it inclined to understeer, and vice versa
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
