Cannot Remove 5th Gear with Puller
Old Sep 1, 2009 | 10:17 AM
gatekiller's Avatar
gatekiller
Stephen Hill
Default Cannot Remove 5th Gear with Puller
I've been trying to remove 5th gear from my gearbox (Mk6 Fiesta IB5) for the last day with no luck. When I start to tighten the gear puller it slips off. Can anyone at all help???
I think the gear puller is supposed to go behind the actual gear but there isn't enough room so I'm putting the lugs on the front of the gear where the is a small ring/ledge.
Please help
Ste
This is the gear puller I bought:
Old Sep 1, 2009 | 11:54 AM
gatekiller's Avatar
gatekiller
Stephen Hill
Anyone?
Old Sep 1, 2009 | 12:37 PM
kjc300's Avatar
kjc300
There is a proper puller for them mate, they are an absolute toad to get off otherwise!!
Old Sep 1, 2009 | 01:38 PM
wing's Avatar
wing
use two legs and put a g-clamp across the legs to stop it slipping or get the proper clamp
Old Sep 1, 2009 | 04:26 PM
Use some/lots of heat as well, always helps, the correct puller would do the job no problem.
Old Sep 1, 2009 | 07:09 PM
JesseT's Avatar
JesseT
It's quite easy to pull the gear to pieces with an incorrect puller.
Hint:
Put your partly stripped gearbox to the trunk. Drive to your nearest Ford workshop. Ask/bribe to get the tool for a five minutes loan.
Old Sep 1, 2009 | 07:15 PM
S1's Avatar
S1
Ive always done mine with a hydraulic press at a mates workshop. Trying to use a mickey-mouse puller will end in tears imho. When you go to put the gear back in, stick it in the oven to heat it up and it will slip straight on the spline.
Old Sep 2, 2009 | 05:50 PM
JesseT's Avatar
JesseT
The proper Ford tool is not too expensive either. I think I paid around 20£ for mine.
Old Sep 2, 2009 | 06:01 PM
RUPERT THE BIG HAIRY BEAR's Avatar
where u from u not got a gearbox specialist near you to go to
Old Sep 6, 2009 | 11:41 AM
gatekiller's Avatar
gatekiller
Stephen Hill
Thanks for the help guys.I eventually found a local gearbox rebuilder who let me borrow the proper gear puller.
Now I'm struggling to put 5th gear back on. Anyone know what Gas Mark and for how long it needs to stay in the oven for?????
Ste
Old Sep 7, 2009 | 11:51 AM
rs combi's Avatar
rs combi
any links to where you can buy the propper ford gear pullers i had to remove 5th of a scrap box with the grinder after it all went a bit wrong with a puller
Old Sep 7, 2009 | 12:20 PM
gatekiller's Avatar
gatekiller
Stephen Hill
I cannot find the specific tool I used, but you need something like this:
http://cgi.ebay.co.uk/GEAR-PULLER-BE...#ht_2746wt_860
Old Sep 7, 2009 | 03:04 PM
rs combi's Avatar
rs combi
as above mate had a normal gear puller on it and sheared the top of the gear
need the propper ford one as i have another box i need to strip to put the lsd out of the scrap box and i dont fancy putting it back in as a 4 speed
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Fudgey
Sep 17, 2015 01:06 PM
