Ford Focus Zetec 2001 X Reg Broken Cigarette Lighter Problem Help Please
Old Aug 31, 2009 | 07:52 PM
misscpb's Avatar
misscpb
Default Ford Focus Zetec 2001 X Reg Broken Cigarette Lighter Problem Help Please
Thanks everyone xxx
Old Aug 31, 2009 | 09:02 PM
maccas1985's Avatar
maccas1985
You will need to check you have supply to the lighter unit. For this you will need a multi meter. The edge of the unit if acting as a earth/neutral, and in the middle at the bottom of the unit is the phase. Usin the multi-meter check for supply to the unit. You could also look at your fuse box and check that the fuse feeding the unit is healthy.
To replace all you need to do is take a very small stroke narrow screw driver and lift the edges of the unit.
Bare in mind though that it may still be live!!!
DO NOT STICK THE SCREW DRIVER IN THE UNIT LIKE YOUR SAT NAV!!!
If you do you blow a fuse and cause further damage.
If you do get the unit out they are very cheap to replace. Your local dealership will be able to supply one, or any decent local auto electrician. They are a simple plug removal installation.
Hope this is of some help.
Macca
Old Sep 1, 2009 | 11:30 AM
misscpb's Avatar
misscpb
Hello Macca
Thank you very much for your help.
Take Care
Misscpb
Old Sep 1, 2009 | 05:12 PM
RichieST's Avatar
RichieST
Highly likely just the fuse. Check the fusebox behind the glove box
Old Sep 2, 2009 | 09:27 AM
misscpb's Avatar
misscpb
Hi Macca & Rich
We checked the fuse box and found out that it needed a new fuse, all is working ok now.
So, thank you all for your advice.
Take Care
Misscpb
JoeyBoyden
Jan 4, 2024 02:36 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
taylora1409
Aug 12, 2015 12:06 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
