starting problem plz help
Old Aug 30, 2009 | 08:56 PM
sexydean's Avatar
sexydean
Default starting problem plz help
rite after my restore, and before i get the interior back in, i think its time to try n sort the bloody starting problem
here we go,
you turn the key to start it, it will turn over for about 1 sec then cut the ignition out for 2 secs then will start again for 1 sec and cut ignition for 2 secs, will keep on doing it unless u jump it off another car then it starts normally, or once n a while it will turn over, cut out and then start,
i have even tryed a new battery
i hope some 1 can help,
if u need any more information of the problem please ask as my comp is on all nite, thanks
Old Aug 31, 2009 | 02:10 PM
badj's Avatar
badj
repeat offender
I'd check the connections on the starter motor are clean and connected properly, then look at earth straps to the chassis from the engine/gearbox. Sounds like the starter isn't getting a good connection.
Old Sep 5, 2009 | 10:55 PM
H.RST's Avatar
H.RST
yer mate I'd say earth strap.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
