gotech gurus help needed
Old Aug 29, 2009 | 12:37 PM
jonny s2's Avatar
jonny s2
Default gotech gurus help needed
i maybe purchacing a full gotech mfi management with loom soon,and would like to know if i could run this on a none rst loom on a cvh with a fezzie coil pack? little silly question i know,and it prob would,much appreciated
Old Aug 29, 2009 | 01:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have not looked at the Jampsort website but IIRC Gotech MFI is designed to use the Dizzy, if you want to run a coil pack you will probably need another version of Gotech.
Old Aug 29, 2009 | 01:17 PM
jonny s2's Avatar
jonny s2
thats what i was thinking,so id need a mfi head,mmmm could i run 250hp through it
Old Aug 29, 2009 | 01:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
There is no difference between a MFI head and a EFI head except the inlet manifold port shapes!
So yes you can run 250bhp on either head
Old Aug 29, 2009 | 01:36 PM
jonny s2's Avatar
jonny s2
if it can run cossie greens though,maybe it can some how run the coil pack..dont the mfi stand for something else on gotech
Old Aug 29, 2009 | 01:39 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
mico fuel injection the mfi uses the dizzy as a triger to fire the injectors if you want to run a coil pack you will need the go-tech mfi pro or the pro x but that uses a 36-1 trigger wheel
Old Aug 29, 2009 | 01:41 PM
jonny s2's Avatar
jonny s2
thats what i meant the inlets different and it runs a dizzy,from what i understand there the same heads apart from this no difference from the 2,so i could run a dizzy on the efi head then
Old Aug 29, 2009 | 01:44 PM
clarke5700's Avatar
clarke5700
im not 100% sure but i tryed fitting a dissy to an efi head and could not get it to fit in the hole and yes i took the blanking plug out
clarke5700's Avatar
clarke5700
ive got an inlet adaptor plate if you are intrested?
Old Aug 29, 2009 | 01:54 PM
jonny s2's Avatar
jonny s2
now this is what i meant,i have a fully rebuilt efi engine...block and head and was wondering if i could run the dizzy,im sure i could of but does not seem the case, the management comes with an mfi inlet and injectors which goes over the gearbox like the 3i style this should be ok to fit efi head,but its the dizzy part which i doubted would fit the efi headif i could run the coilpack it would be perfect,then i wouldnt need to refurb my other mfi head
Old Aug 29, 2009 | 03:50 PM
stevenebm's Avatar
stevenebm
post whore
johnny im 95% sure it cant run a coilpark.defo a dizzy.inlet is for an mfi head but able to take efi injectors.edited as saw karlos g say you can fit a dizzy to efi head.
Old Aug 29, 2009 | 04:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes a dizzy can be fitted to a EFI head, just need to remove the blanking plug!
I dont know why clarke5700 couldnt get his in though?! Can be fiddly lining the slot up in the end of the crank, maybe that was it?
Old Aug 31, 2009 | 08:41 AM
Herbo747's Avatar
Herbo747
how about what with you already running a coil pack you just go for the better version of gotech and use the gotech pro version as you have already won half the battle converting to efi. its a backwards step going back to using a dizzy.
Old Aug 31, 2009 | 09:11 AM
jonny s2's Avatar
jonny s2
yeah a know mate,just saw a cheap as chips management for my second project in rs turbo parts thats all,i already have a dta management for my first project and was gunna use the gotech on my other lol
Old Aug 31, 2009 | 12:56 PM
MattyRST's Avatar
MattyRST
Im looking into the jamsport MFI to EFI gotech conversion, does that run coil packs or does it still use the dizzy ?
Old Aug 31, 2009 | 01:39 PM
jonny s2's Avatar
jonny s2
apparantly the gotech mfi uses cossie injectors or electronic injectors whilst still using the dizzy,this system is for sale in the rs turbo parts section,and would be perfect for you to keep your dizzy and have aftermarket management on the cheap,but if you want to run efi ie.....head coil pack etc you would need the pro or above this is what i have learnt,thanks guys all involved
Old Aug 31, 2009 | 02:57 PM
Herbo747's Avatar
Herbo747
if you opt for the gotech mfi management system they offer a modified inlet, and fuel rail at jamsport, which allows you to continue running the escort rs turbo head. This is the cheaper option as it uses the dizzy to determine engine timing. however the better version, gotech pro or even pro x you will need a flywheel and a crank sensor, you could still get away with leaving the head on from the escort and just use the modified rail to use injectors. my escort rs turbo is going into jamsport next month for gotech pro to be fitted as my rs already uses fiesta efi. going for around the 250 horse power mark.
Old Aug 31, 2009 | 07:23 PM
MattyRST's Avatar
MattyRST
Herbo747 do jamsport supply the flywheel and crank sensor or would i need to supply that myself, what else would i need to run the gotech pro ?
Old Aug 31, 2009 | 07:26 PM
clarke5700's Avatar
clarke5700
nope just could not get it in the hole ill takes some pics 2morro
Old Aug 31, 2009 | 07:29 PM
Herbo747's Avatar
Herbo747
You will basically need to run a complete fiesta rs turbo management system basically to enable yourself to have gotech pro. this way its easier to fit injectors ect. however you are better off supplying your own flywheel and stuff. and fit it all else they will charge you the earth however you wont be able to drive it there without it running so may be difficult. in mine i am running a zvh and i dont think the escort rs turbo block has a cut out the crank sensor. something for you to look at. but for gotech pro i am going to pat around 1000 plus vat for it all to be done and i am supplying my own injectors.
Old Aug 31, 2009 | 08:04 PM
MattyRST's Avatar
MattyRST
Cheers for that Herbo747
Old Aug 31, 2009 | 08:09 PM
clarke5700's Avatar
clarke5700
cheep way of making a 36-1 trigger set up is to use the 1.8 sierra cvh bottom pully as it has the trigger wheel fitted as standard you will also need the timeing belt cover and chop the bottom off as this is where the crank sensor is fitted
Old Aug 31, 2009 | 08:30 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
just a little tip, gotech can run low and high impedence injectors
Old Sep 1, 2009 | 09:27 AM
MattyRST's Avatar
MattyRST
Thanks chaps i think i will go down the EFI route
Old Sep 1, 2009 | 10:16 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I dont think thats right mate, Gotech will have it's own loom?! It doesnt require you to have a Fezzy loom already fitted, what would it want that for?
You might want to use the connectors off the loom for sensors, plugs, etc.. but that would be about it, even then you can buy them new for pennies to make a neater job!
Old Sep 1, 2009 | 10:25 AM
sas's Avatar
sas
should be good!
To run a Gotech Pro or a Pro-X you can use a 1.6, 1.8, 2.0 Zetec flywheel or an EFI CVH flywheel, you use the standard Ford crank sensor.
Gotech is supplied with an almost fully terminated loom.
You can get rid of all the old engine loom and ECU.
You can use the standard water temp sensor in some application and use the Gotech supplied water temp sensor in the other applications.
As said before you can use high and low impedance injectors.
Use the standard Ford coil pack.
Any other questions feel free to ask.
Old Sep 1, 2009 | 11:25 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Ya, thats what I thought!
Old Sep 1, 2009 | 01:36 PM
bennrst's Avatar
bennrst
i run dizzy on efi head
Old Sep 2, 2009 | 07:41 AM
bezo's Avatar
bezo
powered by K26
yer me to, had no issues with mounting the dizzy on the efi head.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
