oil return pipe. would this be suitable?
No it wont!
Been there done that and worn the tshirt!
There is a good reason ford charge Ł30 for them! It will split in a major way and quickly piss all your oil out under the car and probably look like a blown turbo/smoke screen when it hits the hot exhaust downpipe!
Try speaking to rouse or samco, they may not be as cheap as above but probably cheaper than the Ford item!
the oil breather isnt under the same conditions as the return,constant hot oil flow compared to vapour,ask the seller is the easiest way
No it wont!
and..... +1
roose no good i had paul make all mine and thats the only one he did not want to do due to the fact how hot the oil gets and splits the pipe he has made me one but on my head be it if it pops
imo use the correct heat proof ford item
Why not do it in aeroquip? Expensive but would more than do the job and look the bollox?
Although I am happy to admit not many, especially those with an active social life, are bothered about making their oil return pipes look 'the bollox'! LOL!
over 2 yr ago paul made my hoses and my standard pipes he used to make the jig for them
still not drove car jet fooking restros
TBH when there finished I get bored within hours and thats when the trouble starts again!!
