Escort Mk6 brake bleeding question
Old Aug 26, 2009 | 07:54 PM
radicalroadster's Avatar
radicalroadster
Default Escort Mk6 brake bleeding question
Hi guys random question was going to change the brake fluid on the old escort today when someone told me that aparently when you pump the pedal wth the nips open it can cause damage to the master cylinder.
Dunno whether this is the case so i guess my question is when bleeding the brakes is it possible to damage the master cylinder simply by opening the bleed nipple depressing foot brake and closing bleed nipple?
any help would be apreciated.
BTW me escort is a mk6 lx 1800 115ps.
Old Aug 27, 2009 | 01:13 AM
lloydmotorsport's Avatar
lloydmotorsport
cosworth parts specialist
i have known the master cylinder seals to rotate if you press the pedal too fast,just do it slowly and it will be ok,or even better,just gravity bleed them
Old Aug 28, 2009 | 04:21 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Invest in an Eezibleed, job jobbed.
Old Aug 28, 2009 | 04:33 PM
RUPERT THE BIG HAIRY BEAR's Avatar
or make ur own ezeebleed
Old Aug 29, 2009 | 08:08 AM
Eezibleed works well, used it for years without problem.
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
