zetec turbo cheap
I'm breaking my zetec turbo as i have bought a saff cos. the car is mk6 but the engine is a 1.8 zetec turbo
brand new block(not reboured new from ford) painted black
recon head inc all gaskets and cam belt
2x mls head gaskets and 2mm decomp plate
Focus rs spark plugs (gen ford)
2.0l mondeo cams
area6 zetec turbo valve springs
2.0l mondeo throttle body
fiesta rs turbo charge carrier
rs1800 ally thermostate housing
rs1800 inlet manifold
escort rs turbo exhauste manifold and adaptor plate
nissan 200sx injectors
white powder coated cam cover
front breather has been blocked off and relocated to the back
oil return drilled in to block.
brand new t3/4 turbo with 5mm t3 flange spacer
brand new turbo oil feed pipe
-31 collins actuator
this is a complete engine ready to go in your car. £600
Megasquirt2 v3 ecu which is also brand new has no loom £180ono
large front mount intercooler £50
fiesta rs turbo rad not great but no leaks £30
universal oil catch tank £15
loads more stuff will list soon if you want any pics let me no.
cheers,
Phil
2.0l mondeo cams
cheers,
Phil
