whats the best exhaust?
I have had a scorpion and found that too loud. I have just brought a magnex and it sounds better but looks like a C.A.R. add on and just doesn't look right. what else can i try?
[/b]
[/b]
I have been banned from some areas where i live because of noise pollution
I can't believe that
all exhausts can be quiet if driven correctly if not you may need to have a custom made powerflow jobbie, not as expensive as people think
Originally Posted by discodenkelly
I've got an extreme one from woodford garage, sounds sweet and looks good too
Magnex will be the quietest choice - available with 3" or 4" tailpipe.
Hi, I have tried Scorpion, Mongoose, Magnex and now Exstreme. They all seems to be a bit loud, but only when going
. And all is "booming" inside around 24-2800rpm, so it all is down to personal taste....I think.
The one I'll keep will be the Extreme
, because it fits so well, and its so easy to work with.......compared to the others !!! So best choice in my opinion is ....... the EXTREME zorst !
Yes the EXTREME is essentially a Mongoose with a 4" slash cut tail, and it's cheaper, it's easy'er to fit and take apart and last but not last it "fits" alot better than the "Goose".... my opinion ...
CheeRS
.... The one I'll keep will be the Extreme
, because it fits so well, and its so easy to work with.......compared to the others !!! So best choice in my opinion is ....... the EXTREME zorst !Yes the EXTREME is essentially a Mongoose with a 4" slash cut tail, and it's cheaper, it's easy'er to fit and take apart and last but not last it "fits" alot better than the "Goose".... my opinion ...
CheeRS
picking my saph up on friday night which has an ashley compatition system on it, from past experience these systems have always been very loud on my other cars,
has anyone else got one?arethey any good? should i throw it in the bin? and get myself a proper system
i always liked scorpion buy u say too noisey but my friend had a powerflow one fitted built very well and u can choose too a level how loud u want it it sounds great on his cossie and not loud at all and was only 260 pounds hope this helps
I have a scorpion on my 4x4 , whats annoying is that in fifth gear at 60-65 mph it drones like a bastid, but having said that i dont sit at 60 very often so i guess it aint that big of a deal
What i will say is that you cant beat the sound of a scorpion attached to a cossie at full throttle
