Zetec engine quest - can you fit??
Old Aug 25, 2009 | 09:13 AM
hineho87's Avatar
hineho87
Default Zetec engine quest - can you fit??
Hi,
First got a 2001 focus 1.8.
Lookin at things i can do next but dont want be spendin loads for minimal gains as swappion car in 6mths!. Seen a few posts here and elsewhere about fittin an ST170 throttle body and wondered how easy it is to fit to . Also wot about TB, cams (or zetec 136ps cams if they arent the same thing) and MAF from a GTI 1.8 or 2.0 mondy etc and again do they fit and r they a straight fit?
Jus want sumthin different and then wont cost a bomb to fit!!
Any other ideas appreciated!
Matt
Old Aug 26, 2009 | 10:12 AM
JesseT's Avatar
JesseT
Cams is supposed to do by far the biggest part of the difference.
Old Aug 26, 2009 | 10:24 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
whack the cams in and the ecu from a 136 spec, will map better then
Old Aug 26, 2009 | 11:25 AM
hineho87's Avatar
hineho87
Will the zetec 136ps cams/ecu from a silvertop fit striaght into my blacktop focus as i thought the cams were different (one hydraulic and other mechanical lifters) Does that make any difference?
If they do fit wot gains wud they roughly give me? Iv currently got st170 manifold/cat with S.S cat-back with K&N induction kit?
Matt
Old Aug 26, 2009 | 01:22 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i didn't read properly, nope, blacktop and silver top bits don't swap over, quite different engines.
Old Aug 26, 2009 | 02:27 PM
hineho87's Avatar
hineho87
no worries m8, thought this woz the case but i cud neva get a definative answer.
my m8 knows sum1 sellin a ported 1.8 head wit kent cams so may get that
Matt
Old Aug 26, 2009 | 02:37 PM
jonny s2's Avatar
jonny s2
Zetec heads are quite good standard,black top have solid lifters and i believe are better than silver top heads anyhow
Old Aug 26, 2009 | 02:44 PM
hineho87's Avatar
hineho87
u think it is worthwhile either porting my 1.8 or buying that ported 1.8 one or do u not think there will be any gains?
Matt
Old Aug 26, 2009 | 02:52 PM
jonny s2's Avatar
jonny s2
Tbh mate if you have not done anything else to the engine it would be pointless,also if you are buying another car in 6 months or so and not planning to do any drastic mods,i would leave as is,put that cash aside for the next car. You would be wasting money on nothing
Old Aug 26, 2009 | 03:17 PM
hineho87's Avatar
hineho87
fair enuf m8, yea only things i woz lookin at woz cams wit remap. Then herd bout the bloke sellin the ported head and jus wanted to see if it woz worthwhile. If i modded this car to a reasonable power (150ish or more if possibel without spendin stupid amounts) i would keep it for longer, especially as i want an focus st/rs or fiesta st, which arent cheap and i wud want mod them as well it wud allow me to save up a bit more!!!
Matt
JoeyBoyden
Jan 4, 2024 02:36 PM
Porplus12
Sep 10, 2015 07:20 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
