wiring ppl good with relays - please advise.
right, i'm hoping this makes sense so here goes.
i need to wire 2 relays in, 1 is going to my omex ecu and the other to my fuel pump with a direct 12v feed from the battery. i've got all the wires there now but no idea what pin on the relay i need to put the wires to so can anyone give me any pointers?
i'm using standard ford 4 pin 40 amp relays with the metal clips on, looking at the relay with the metal clip at the top i have numbers going clockwise 30, 87, 85 and 86.
i've "borrowed" a bit of omex wiring diagram and added a bit in myself so you can see what i'm trying to do.
be very gratefull if anyone could help?
i have an escort rs turbo have had problems with the fuel pump relay someone please help what are pin 31- for then 15-11 then 1-3 then 54-15 then 30-28 as i want to rewire it as someone has bodged it before i have a permanent live an ignition live fuel pump supply and some more i guess an earth and i think its an ecu signal what do they go to any help will be aprecciated thanks
DixieTheKid
Jul 23, 2023 10:16 AM
kosienutter
31
Aug 22, 2015 09:55 AM
