Is It The Diff? Advice Needed Lads!!!!
Old Aug 22, 2009 | 05:06 PM
m_nettleship's Avatar
m_nettleship
Default Is It The Diff? Advice Needed Lads!!!!
Its m3 evo 5 door, wen its under hard throttle it drives brill no problems, but wen the camber changes of the road or goes a little bumpy, it feels like the rear end is trying to steer! only at 90mph plus. It Only does this if say u go over a bit on a hill, mainly wen the road changes from being flat. Very hard to explain!!!
Our theory maybe that its somethin to do woth the diff witch is lsd, and i think its a plated one! Thinking that maybe wen the weight moves off one side of the car, its sendin more power to one wheel.
Its actuallly dangerous, u be driving hard to 100 go over a little hill or somthing and it will force to one side. Hope someone can help, The diif its noisy at all, and its fully 4 wheel alighined! camber and tracking all spot on. It gets very twitchy on uneven sufaces.
Thanks Matt.
Old Aug 22, 2009 | 05:14 PM
LHD220Turbo's Avatar
LHD220Turbo
i guess you have checked all the obvious things for something wrong not tight etc?
i have seen 3 m3's which have crack the metal bracket where the diff is mounted - but i doubt that would give you the problems your experiencing
Matt
Old Aug 22, 2009 | 05:18 PM
m_nettleship
thats brand new as ive split that b4. Yeah everything else okay.
Old Aug 22, 2009 | 07:57 PM
m_nettleship
btt
Old Aug 22, 2009 | 08:09 PM
andy130's Avatar
andy130
bearing?
Old Aug 22, 2009 | 08:20 PM
m_nettleship
wheel bearing? would i hear that tho?
Old Aug 22, 2009 | 08:23 PM
Jim Galbally's Avatar
Jim Galbally
i just had the same thing on the MR2 and it was sometihng not bolted up properly on the rear suspension/beam.
doesnt sound like the diff to me
Old Aug 22, 2009 | 08:25 PM
andy130's Avatar
andy130
true check bushes?
Old Aug 22, 2009 | 08:37 PM
Teej's Avatar
Teej
Rear arm bushes up near the rear inner sills, thats the usual fault, when split/worn they can cause a shit load of play at the rear wheels.
Old Aug 22, 2009 | 09:06 PM
Jim Galbally
ofcourse yeah, the rear trailing arm bushes are VERY common to fail.
so are the rear topmounts
Chas
Sep 21, 2015 08:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
knight19770
Aug 4, 2015 12:36 PM
COLEYST200
Aug 3, 2015 08:55 AM
