wiring help please!
Old Aug 22, 2009 | 04:13 PM
john_p_b's Avatar
john_p_b
Default wiring help please!
just in the final stages of fitting omex to my saph and now fitting the relays.
am i right in thinking i need to put a fuse along side the relays? (got 1 relay going to ecu and one will be used for fuel pump.
so would i be correct in putting a fuse in the switched (ignition) feed to the relays? what amp fuse should i be using? using the standard ford 40 amp 4 pin relays if that makes any odds?
Old Aug 22, 2009 | 05:33 PM
oldford's Avatar
oldford
Ford had the fuses the supply to the relay, not in the switched feed.
For wiring diagram: http://www.siipicossu.com/manuaaleja/manuaalit.htm
Old Aug 22, 2009 | 05:55 PM
john_p_b's Avatar
john_p_b
yep sussed it now thanks. amazing what happens when i engage some brain cells!
Old Aug 22, 2009 | 06:30 PM
You always supply the feed 30 or 30/51 with the fuse between it and the power source/battery.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
