cossie 4wd oil pump cracking??
Old Aug 21, 2009 | 07:17 PM
forevaford's Avatar
forevaford
Default cossie 4wd oil pump cracking??
hi guys, iv had this problem on my 4x4 saph since rebuilt it
noisy tappets, mainly on tickover, and it takes a long time for the oil pressure light to go off when restarting (after standing a while), it was built with new cosworth high pressure oil pump, and has always had good pressure. (2bar at warm idle) still has noisy tappets (new genuine ina)
i did prime the oil system with a drill on the aux pulley before start up!! with belt off.
could this be a cracked pump of sum sort??
also im converting the car to 2wd format verry soon, so i will be investigating the pump then, i think i will need a 2wd pump with a 2wd sump wont i??
which pumps are recomended (2wd)
thank for any info
martin
Old Aug 21, 2009 | 07:20 PM
forevaford's Avatar
forevaford
it takes about 7 seconds for the light to go out!
i spose it could be a leaky pick up pipe or pump seal to block??
Old Aug 21, 2009 | 08:01 PM
Barry R's Avatar
Barry R
Mine goes out as soon as it starts
Old Aug 22, 2009 | 06:48 PM
7 secs is real bad, should be out within a second.
The noisy tappets can be down to low mileage if new ?, some do take a few miles to fully quieten, some of mine took 50 miles till totally happy, and ones buggered up now!
The most likely cause is the oil filter allowing drain back, this has/should have a spring loaded disc inside which keeps the system full of oil after shut down, so could be a simple filter change to sort, I recommend MAHLE, I won't use a ford one, too much rust inside for my liking, had a few ford ones leak from inside out due to rust as well.
Old Aug 24, 2009 | 10:51 PM
forevaford's Avatar
forevaford
ummm, thanks tabetha,
i have don around 4 k miles since rebuild, changing the oil and filter several time to cure this, including tappet changes. found no differance. iv measured tappet to bore clearances- all fine. iv had the head off to check the oil return valve ball bearing thingy, all seemed fine. im convinced now that their is a problem with the pump itself or pickup seal, or even pump seal to block. i no iv got a problem sumware. actual oil pressure wen running is in good.
my theory is if a pickup pipe is leaking then pressurised oil system will be airated hence playing my tappets up etc ??????? tabetha?
Old Aug 26, 2009 | 06:19 PM
forevaford's Avatar
forevaford
the pump has cosworth imbedded on the bak of the pump so its a cosworth 1?????
Old Aug 28, 2009 | 03:45 PM
forevaford's Avatar
forevaford
fuckin shit cossies
Old Aug 30, 2009 | 04:35 PM
forevaford's Avatar
forevaford
after remove of "cosworth" high pressure pump, i can see a light crack in the rear of the pump housing... ummm
big_Rad
Sep 15, 2017 09:36 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
Dubs44
Aug 21, 2015 02:42 PM
lockie
Jul 31, 2015 10:03 PM
