gearbox
Old Aug 20, 2009 | 03:58 PM
Korda's Avatar
Korda
Default gearbox
looking at getting a cheap s2 with gearbox going in 2nd. harf to find a good gearbox if any. what diesel boxe would fit
Old Aug 20, 2009 | 07:31 PM
botters's Avatar
botters
competant bodger
not to difficult to find rst box mate you can genearally get a full rebuild done on them for less than 300 quid. i wouldnt bother with a diesel box mate its a myth that they are stronger they are the same as rs box except for sliightly taller ratios and no lsd
Old Aug 23, 2009 | 10:59 AM
Korda's Avatar
Korda
will the mk5/6 diesel gearbox fit the rs turbo and the clutch any mods neede to fit
Old Aug 24, 2009 | 05:30 AM
cabrst's Avatar
cabrst
it will fit
but try to read what we say.....
THE DIESEL BOX ANIT STRONGER THAN THE NORNAL 1600 box
its a myth that keep poping up, from some one that havn't got a clue about what they are talking about...
the only diffrent between the diesel and the standard S2 box is the ratios + you will loose the LSD diff
Old Aug 24, 2009 | 05:57 AM
Korda's Avatar
Korda
ok thanks for info
Old Aug 24, 2009 | 06:57 AM
DanRSturbo's Avatar
DanRSturbo
You can put a diesel box in it if it is standard power.
Old Aug 24, 2009 | 07:15 AM
Karlos G's Avatar
Karlos G
Balls Deep!
But why would you want to?? Less accelaration and more top end??
Old Aug 24, 2009 | 09:11 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it helps lose some of the wheelspin and better on economy on cruising, they are the reasons i have diesel gear ratios.
Old Aug 24, 2009 | 09:32 AM
JesseT's Avatar
JesseT
Same here, I have the 3.54 final drive from a mk1 diesel Orion. Much nicer altogether, even more so when you have a 2.0 zetec turbo. Much quieter on higher speeds and actually better acceleration from 0-100km/h.
Old Aug 24, 2009 | 03:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I guess it's just personal opinions but i hated running a Diesel box, much prefer the normal RS ratios.
Old Aug 24, 2009 | 05:20 PM
Korda's Avatar
Korda
the car was cheap just wanted a quick fix turned out to be a dog so the hunt carrys on
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
