comp on 300+ cvh
Old Aug 18, 2009 | 10:45 PM
little bram's Avatar
little bram
Default comp on 300+ cvh
am building a new engine for my escort and was wanting to no what compression would work best. Am still running a 1.6 and i was wanting to run standard comp so id hav little turbo lag.
iv got wossner pistions and steel rods at standard comp, i would think it would be ok to get the pistons skimed down to low the comp what do uses think. am wanting 300+ bhp
thank
Old Aug 19, 2009 | 08:52 AM
morph's Avatar
morph
thank
if you are going to run in excess of 300bhp then you should get the wossner pistons machine down, they can be machined to 7.5:1 as that is what i had done.
Old Aug 19, 2009 | 12:02 PM
sas's Avatar
sas
should be good!
I am running mine at 7.1:1 Its has run fine for 18 months.
Simon.
Old Aug 19, 2009 | 04:08 PM
morph's Avatar
morph
Simon.
yours isn't a cvh bottom end is it though?
Old Aug 19, 2009 | 04:26 PM
JamboRS's Avatar
JamboRS
focus rs 1672
firstly low comp wont give u lag if u spec it right,so use the smallest turbo to achieve the figures
whats the rest of the spec?turbo etc? as u cant ask a question like that and get answers when no-one knows ur spec,and picking a comp ratio because someone told u on the net will never work,spec it right and it will be awesome,mix match of parts and itll be a disaster
Old Aug 19, 2009 | 07:07 PM
little bram
thanks ppl,
the spec of the engine will be changing next year as i lik trying new things and always want more power.
The spec this year is
1.6 cvh block bored out to .5 + its being skimmed 6 thou
std crank reground to .25
wossner pistions std comp and steel rods
big valve, ported head
piper t2 cam, will be geting changed to newmans
cosworth management with l8 ecu + pectel bord
ligth blue injectors (400's)
cossy t3 turbo with 360 bearing and 48 exh housing
am wanting to keep the block and head the same and change diffrent thinks lik cam and turbo to get more and more power and see what works best. just wanting a good test bed. i did read that nick from performance ford and jamie at jamsport are runing 9:1 with theres and it goes realy well
thank again
Old Aug 20, 2009 | 07:01 PM
project rs's Avatar
project rs
i'd personally run around 7.7-1 and put a roller bearing turbo on something like the gt28rs or 2871 as they spool up really quick, not to sure what a gt25 would be like for making 300hp though or even the new roller bearing t3's that are about to come out that jamie is testing on nick's car are suppopsed to be excellent but all the above are pricey
Old Aug 20, 2009 | 09:47 PM
morph's Avatar
morph
what mods do you need to run a gt28 turbo?
Old Aug 21, 2009 | 06:42 AM
crazycage's Avatar
crazycage
manifold and down pipe,or just a down pipe if you get one with a t3 exhaust housing on it.
Old Aug 21, 2009 | 09:06 AM
matt p's Avatar
matt p
thanks ppl,
thank again
Sure does matey, it made mincemeat out of an audi RS4 at brands hatch on wednesday night.
Old Aug 22, 2009 | 09:07 PM
little bram
well ppl being on the phone to 4 tuners and some arnt very helpful unless they think you are going to get some work done. so il not b telling any1 to go to them or get my cars set up there if they can be arst to give some advise.
the two ppl that where very helpful where harvey gibbs wife witch i didnt get bk to(sorry) and simon at sitech who was very helpful, thanks mate top man.
after talking to simon i no witch way am going to go now and iv spec my engine to what i want. just need to start building it now
Old Aug 23, 2009 | 04:39 PM
bazpro's Avatar
bazpro
u not getting another cozzy like? seen your car a couple of month back over durham and it looked clean as fuck. wot sort of power has it got now?
Old Aug 24, 2009 | 08:49 PM
little bram
not yet mate. got it set up and was about 270bhp mate. but then snaped a rod.
you still got you escort
Old Aug 28, 2009 | 04:58 PM
bazpro's Avatar
bazpro
fuck me 270 in a escort must be mental. nah sold the escort about a month ago got offered a price i couldnt refuse. just bought a s14 200 sx to smoke about in for a bit.
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Russp
Escort Range
Sep 18, 2015 07:39 PM
