Alternator charging question:)
Old Aug 18, 2009 | 05:28 PM
Chris Honeywell's Avatar
Chris Honeywell
Default Alternator charging question:)
With everything on IE air-con lights etc what should the voltage be across the battery??
Same with everything off.
I Get 13v with everything off
and from 11.5 to 12.5 with everything on .
Anyone got an idea of what it should be MINIMUM for both??
Old Aug 18, 2009 | 07:29 PM
cabriolet's Avatar
cabriolet
it sounds about right to me does the voltage recover when u rev the engine voltage can drop momentarily on crank to 9 volts
Old Aug 21, 2009 | 08:22 AM
If 11.5 to 12.5 was with the engine idling then that's fine, so long as by 2000rpm it is high 12's or low 13's then that's fine.
jonfoc
16
Sep 11, 2018 05:35 PM
dojj
111
Jun 10, 2018 09:09 PM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
