Pf01 and Pf09 Throttle Position Sensors
Old Aug 18, 2009 | 09:58 AM
JokerDisco's Avatar
JokerDisco
Default Pf01 and Pf09 Throttle Position Sensors
Can anybody tell me whether you can tell the difference between a pf01 and a pf09 Throttle Position Sensor just by looking at them???
Am I right in saying that the pf01 came in red and the pf09 came in black?
I know internally that they are the same apart from the voltage readings work in reverse.
I cant remember which one I have bought but I did have to reverse the TPS wires to run the car on a L8 when trying to get it running- does that mean it must be a pf09
I think I bought a pfo9 to run a L6 ecu with the cossie management on the series 2. I've since found out that I will require a pf01 to run a L6 ECU.
Anybody help please?
Old Aug 18, 2009 | 09:59 AM
RS500/364's Avatar
RS500/364
01 red and two outer wire need to swap for the 09 BLACK
Old Aug 18, 2009 | 10:06 AM
JokerDisco's Avatar
JokerDisco
Can you explain that a bit more???
Maybe I was unclear:
I bought a level 6 ECU to run the cossie management on my series 2, at around the same time I "think" i bought a Pf09 but cannot remember.
When we were trying to get the car running for the first time I lent my mates ECU which was a L8. The car didn’t run until I reversed the two wires on the TPS.
Now would you say that the TPS is a pf09 or a pf01???? Baring in mind that I belive both the pf01 and pf09 are identical internally and electrically apart from the pf09 is backwards i.e works in reverse.
So regardless of whether it is a pf01 or a pf09 you can run either on a L6 providing you have the wires the right way round???
Old Aug 18, 2009 | 10:21 AM
AJC's Avatar
AJC
you need a pf01 to run l6. It should have it written on it. Early pf09s were also red.
Old Aug 18, 2009 | 10:23 AM
AJC's Avatar
AJC
i have several pf01s. You can have one. Send me a sae bubble wrap envelope and i'll send you one. Pm me for my addy if you'd like one.
Old Aug 18, 2009 | 10:30 AM
JokerDisco's Avatar
JokerDisco
Thanks mate.
I have had to reverse the TPS wires to run my car with a L8 ECU. Will that mean that once I put the pf01 on then I will have to switch the wires abck to normal??
Or did I reverse the wires to run the L8 ECU becuase it is infact a pf01 and I needed to reverse them to get the thing running? If so I can just swap the wires back around then it will be good to run the L6.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
