Whos cars don't start after 2weeks?
As its winter my car is often bein left covered up for upto 2weeks at a time, outside, without bein driven, when i do go to drive it it doesn't start on its own power and quickly needs to be wired up to another car or battery to give it the minerals. Does anyone else have to do this?
Thats because the average car is drawing 0.1 - 0.2 amps from the battery even when you are not using it. If two weeks = 14 days x 24 hours = 336 hours, then thats between 33.6 - 67.2 amps being taken away from your battery.
left my frst for 2 weeks came to it started fine!!
apart from loads of blue smoking keeps pouring out of exhaust lol
but it doesnt start normally i.e. wont start and run everyday!! its backwards my car is!!
Mines exactly the same. I was going to post the same question. Was gonna take cossie for a spin cos the sun was out. Didn't start cos battery was flat
. Dug out the charger and it started raining
Fook that, it can stay in the garage. Don't want to get it wet
.Fook that, it can stay in the garage. Don't want to get it wet
sooooooo what i done
how can i tell the curant being drawn from the car btw
and if it is the light in the boot im not gonna post as i mught look silly
now when i get a min im gonna go out and charge the battery this week
then check the oil too, been told ya have to do that on cossies
, never had to check oil on my cabrio
, i know when thats low as its used more petrol than normal
[quote="b19bal"]
I third that!!
I third that!!
Don't think the light in my boot even works!? I went on hol for just over two weeks in the summer, when i got back my car started first time (just)!! It seems that my car doesn't like the cold, i think it gets affected by cold and damp, it used to be garaged until not to long ago and it was never as bad as it is now!?
i drive a K reg Nissan Sunny 1.4LX and it starts first time every time even after not driving it for 3 weeks. i hate it but i got to give it credit for reliability. hopefully gonna be driving a ford soon
I had exactly the same problem. Mine would be fine for weeks over the summer, but come the winter if it wasnt run every week the battery wouldnt hold enough power and would be dead when i did come to start it.
I bought a new heavy duty (bigger battery) Bosch silver for my RST and has been fine since.
Also does your started motor turn over slower in winter even if the car has just been out and run for a few miles? Mine did and the new battery cured this.
You ideally need an amps clamp meter. Which you can place around your batterys positive wires or negative wires (whichever fits best) and the meter will tell you how much current is being taken from your battery.
CabrioTurbo
Aug 1, 2015 11:04 AM
