2wd clutch problem
Old Aug 13, 2009 | 04:59 PM
glover's Avatar
glover
Default 2wd clutch problem
hey, i have just bought a 2wd cossie with a noisy thrust bearing the car has an ap racing clutch from what i have been told from the previous onwer i have got a new standard cossie clutch from him i am just wanting to know is it stright foward enough to remove the box on its own without lifting the engine out..
cheers neill
Old Aug 14, 2009 | 12:25 PM
Yes quite easy to do on it's own, if the bearing is just a bit noisy when the pedal is up and goes when you press the pedal, most live with it, as it is usually not a problem, but if really noisy obviously change it.
Just back off the adjuster at the pedal first by pulling pedal up then pushing adjuster pawl forwards say 1" release press pedal a few times to reset the auto adjuster, maybe it has taken up too much slack so it is riding the clutch ?
Old Aug 14, 2009 | 05:03 PM
glover's Avatar
glover
when the care is ticking over it is quiet once you put your foot on the clutch to select a gear the noise is unreal.
cheers neill
Old Aug 14, 2009 | 05:36 PM
In that case it defo needs changing now.
Old Aug 14, 2009 | 08:06 PM
glover's Avatar
glover
well when i was out working at the temp sender tonight i notice the top 2 and the side bell housing bolts where slack even the one with the earth strap where only finger tight so i tighten them all up fired up the car put the cluth pedal in and the noise is away altoghter now happy days
cheers neill
Old Aug 15, 2009 | 10:16 AM
Happy days that was an easy fix, why can't previous owners bolt things together correctly though!!
You are very lucky with a loose main earth cable that you didn't fry your engine loom and ecu, as having seen this before it tries to use the ecu earth points to power up starter.
cossiedean84
37
Sep 2, 2015 10:19 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
