Second opinions needed please
Old Aug 12, 2009 | 06:13 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Exclamation Second opinions needed please
Ok this may be a bit of medium sized thread but could do with some advice:
First of all i have a issue with my Escort cosworth, when i start it up the oil pressure shoots up to just below the 5 bar, however when the car reaches normal temp and the revs have dropped down the pressure on the gauge reads above the red, the previous owner run it on and just changed the oil to castrol magnetic 15/40 which i think is to thick, i used to run my other cosssies on 10/60????? Now could it be that the oil is to thick or is my oil pump giving up??????.
The car was originally a small turbo but at some time been converted into a large turbo model however im unsure if it is a 4x4 engine or 2wd with the added sump modifications to make it a 4x4, is there a quick way i can tell.
The alarm never come with the code so i can change the features on the alarm is there a way i could get if i contacted clifford but then a previous owner may of changed it since then?????
I hope you may be able to answer these questions.
With kind regards
Steve
Old Aug 12, 2009 | 06:18 PM
dom123's Avatar
dom123
are you talking about the escort cossie gauges in the middle of the dash if so there so unacurite its unture i would get a race tech oil pressure gauge as oil pumps to the back of the gauge and the reading are true. so shity loose or rusty connections! i wouldnt assume the worst mate.
the engine will have 200 casted on the side of it under the turbo
and you need to use a cliffnet cd rom to sort your alarm out
Old Aug 12, 2009 | 06:25 PM
392B.H.P.SAFF
dom123
Thankyou for your quick reply, i was fearing the worse so will get a seperate gauge and hook up.
Where would i get the cliffnet cd rom from and where would i get the connection lead from the pc to the brains of the alarm?????
Old Aug 12, 2009 | 06:37 PM
JK99's Avatar
JK99
I'm glad you 2 understand each other!
As said, get a different gauge and get a reading from there. Hope it's nothing serious.
Old Aug 13, 2009 | 06:01 PM
dom123's Avatar
dom123
ebay sell a cliffnet cd rom and lead its about Ł30ish
Old Aug 14, 2009 | 12:20 PM
The castrol magnetec 15W40 is THINNER than your 10W60, it may be getting too thin, especially after a blast, the thinner it is the more pressure drops.
I would try your 10W60 in it, as long as you are using FULLY synthetic it will be fine, mineral oils tend to break down way too easily.
The gauges are notoriously inaccurate, just put some decent 10W60, or some 15W50 mobil 1 in there and see what the gauge says, but don't worry anyway.
Red_bull
Aug 25, 2015 06:27 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
col93saphcos
Aug 7, 2015 03:21 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
vdubo7
Aug 2, 2015 08:17 PM
