Escort mk4 xr3i efi
Old Aug 11, 2009 | 11:07 AM
fastford79's Avatar
fastford79
Default Escort mk4 xr3i efi
Hello
I'm thinking of turboing my xr3i. What do i have to do
whit the enginemanagement, injectors, etc to make it work?
Old Aug 11, 2009 | 11:44 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you can go the frst route, then it's only a few little mods to the loom then, if you go megasquirt, then it's even simpler, just chop the wires on the ecu plug and use what you need from the inputs.
Old Aug 12, 2009 | 09:23 AM
fastford79's Avatar
fastford79
Do you know if there is a step by step guide how to convert to fiesta rst?
Old Aug 12, 2009 | 09:48 AM
orion88's Avatar
orion88
its not all as simple as that tho mate
u will need and oil return strenthened bottom end lsd brakes exhaust turbo the efi loom is easy u just unplug the old loom and add the new one it all unplugs easy job but its more the hardware things u need you would be better just buying a frs and dropping the engine in ur xr3 personally id go better and 2ltr zetec turbo it
Old Aug 12, 2009 | 09:49 AM
orion88's Avatar
orion88
http://www.rsbible.co.uk/escort/efi.htm
Old Aug 12, 2009 | 12:28 PM
fastford79's Avatar
fastford79
Smile
Originally Posted by orion88
Thanks
Old Aug 12, 2009 | 01:25 PM
fastford79's Avatar
fastford79
We don't have fiesta rst here in Norway so can't just buy one and drop in the engine. Have all the other bits from an escort rst so that is no problem..
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
bigryrs
Sep 7, 2015 06:45 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
