coilpacks on P8
Old Aug 10, 2009 | 11:20 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default coilpacks on P8
From what i understand the P8 generation ECU is capable of running a coilpack with a software mod and the appropriate loom fitting.
Now was this something ford asked to be optional (yet not used) or was it a function used by other cars using the same webber p8 system????
Now being a software function does this mean that a P8 coilpack loom is the same, where as L8 etc the loom depends on the wiring needs of the coilpack driver??
Was this something used in the grpN and other lower spec motorsport ESCOS or did they all go for the higher spec Pectel ECU's????
Old Aug 11, 2009 | 06:21 AM
oldford's Avatar
oldford
Coil pack was used on P8's in the Lancia Delta Integrale 16V.
Whether or not the hardware is present in a Ford P8 I don't know.
It was not used for group N. The Group N regulations forbid this.
It was used with Pectel ecu's on group A's and WRC's.
Old Aug 11, 2009 | 12:11 PM
Psycho Warren
Carbon Crazy
Interesting!! I do wonder if the core P8 architecture is the same!
Old Aug 11, 2009 | 06:08 PM
oldford's Avatar
oldford
Yes, the architecture for a Lancia P8 and a Ford P8 is the same.
Even most of the pins on the connector are on the same place.
It's the software that's different.
Old Aug 14, 2009 | 09:58 PM
markk's Avatar
markk
the P8 runs coil pack as std with just a software mod
Old Aug 14, 2009 | 11:28 PM
Psycho Warren
Carbon Crazy
mark have you got a wiring diagram for standard P8 with coilpack????
Old Aug 14, 2009 | 11:33 PM
markk's Avatar
markk
hmmm i cant remember if i have or not, i used it on my last car, you need to add an extra ign amp, and a pin to the ecu, that then gives you the two signals fo rthe wasted spark, pin 26 iirc. i would have to have a look through my archives as i dont use that anymore.
Old Aug 15, 2009 | 06:55 AM
Stu @ M Developments's Avatar
PassionFords Creator
We sell all the parts for this conversion. The P8 has it inbuilt as standard and is almost the same as the P8 used for other marques.
Old Aug 15, 2009 | 09:05 PM
Psycho Warren
Carbon Crazy
I know you sell all the bits stu, and I'll probably get you to do a coilpack conversion when i finally get the funds to sort a chip (once ive done the more critical things like no suspension, a leaking rad, dead fuel pump and fan wiring, etc the list keeps growing!).
But im not looking to fit an off the shelf coilpack loom as i doubt it will be the correct lengths for how im building my new engine loom which is going to be custom lengthed for my puma and i want the ign amp wiring, coilpack wiring etc encapsulated into the new loom i build as a complete engine loom.
Old Sep 6, 2009 | 07:49 PM
markk's Avatar
markk
you do still need to use two ign amps, and the wiring is very simple pins 24/25 from ecu to pin 3 on ign amps, pins one from each amp to the respective switch side of the coils.
Old Sep 10, 2009 | 08:42 PM
Lars_Ferm's Avatar
Lars_Ferm
iv heard that there has been some problems whit high rpm and boost whit the coilpack? im thinking of one but if it wont work great whit my 500hp/8200rpm/2bar boost its money i could have used on other things?And Stu-isnt there a direct fire support in p8? whit 4 coils and no leads?i friend of mine has got this to work whit a p8 and some mods its in a test face now.
bigluke200
14
Sep 2, 2015 10:35 PM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 15, 2015 10:43 AM
FAST AS FORD
Feb 23, 2006 05:52 AM
Cossie Sean
35
Dec 8, 2005 12:20 PM
