ET25 too small??
Old Aug 6, 2009 | 04:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default ET25 too small??
As above is a offset of ET25 too small on 7x16's, lowered 35mm, will they rub? Standard wheels are ET35 IIRC.
Cheers!
Old Aug 6, 2009 | 04:22 PM
jonny s2's Avatar
jonny s2
they should be alright mate,et25 will make the wheels sit further out the arches,infact with 7" wide should sit spot on
Old Aug 6, 2009 | 04:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah thats what I was thinking, cheers!
Old Aug 6, 2009 | 05:09 PM
crazycage's Avatar
crazycage
i would go for et35 and space out if you need to your fucked if the et25 is out to far.
Old Aug 6, 2009 | 06:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I thought of that but the wheels I want i can only get in ET25 16's, or ET40 17's
Old Aug 6, 2009 | 08:43 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I run 7x16" ET30, wouldn't want them any further out than they are TBH.
Old Aug 6, 2009 | 10:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh really? Pain!!
Old Aug 7, 2009 | 06:28 PM
jonny s2's Avatar
jonny s2
7" wide you will be ok,i ran et35 17"x7.5 and they were level with the arches
Old Aug 8, 2009 | 05:48 AM
JesseT's Avatar
JesseT
I'd definately go for the ET40. Too high of an ET you can always correct out with spacers, but too low is more tricky.
I have 16x7.5" wheels with ET38 and I would want it an millimeter more in or out. It's very close to rubbing both to the rear shock and rear outer wing.
Old Aug 8, 2009 | 09:07 AM
Karlos G's Avatar
Karlos G
Balls Deep!
7.5" wide is 6.75mm wider in each direction, then ET35 would put it 10mm inwards, so 7" ET25 would be 3.25mm closer to the outer arch which if yours were level is too close, they would rub!
Yeah but the ET40 are 17's and that's the problem I want to drop to 16's
Old Aug 8, 2009 | 09:23 AM
jonny s2's Avatar
jonny s2
have you seen escort cosworth wheels,et25 8j they stick out a little yeah people fit these still, but if you fit 7" wide et25 how are they gunna rub? ive ran this offset and were ok,but ive now gone back to et35 due to using a ford alloy wheel
Old Aug 8, 2009 | 09:24 AM
jonny s2's Avatar
jonny s2
et25 gives a wider stance
Old Aug 8, 2009 | 11:46 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats a good point!!
Old Aug 8, 2009 | 01:16 PM
RSandy's Avatar
RSandy
dude, im assuming you have probably already given the aches a little bit of loving to get your 17s on with it lowered, so that will be plenty enough gain to easily clear et25 16s
and as said, esc cos rims are 8j et25, and they fit with just a bit of arch work and the correct tyres
Old Aug 8, 2009 | 01:24 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
i had voodoos et25 on a s2 195 tyres it used to rub like a bastard going round corners with the archs totally modified that was 25mm lowerd the only way i can see you can get away with it is keep standard ride height
if you keep it that low it will rub the arch away and your wheels will come through the archs also note its the weight of the wheels that dictates the handling not just the size if your a lighter weight 17 will handle better than a heavier 16
Old Aug 8, 2009 | 06:07 PM
Oranoco's Avatar
Oranoco
I'd keep as close to ET35 as possible personally. Driven a few Escorts and Fiesta's on Escort Cossie rims (ET25 8J) and imho they drive like shit on them
Old Aug 9, 2009 | 02:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have done nothing to my arches to fit the 17's, and I only get a tiny bit of rubbage at full lock.
Were they 16's or 17's?? If they were 16's then I have no hope
Yeah I bet!!
Old Aug 9, 2009 | 02:08 PM
jonny s2's Avatar
jonny s2
it is best to get as close to the standard offset as poss,but if your wanting custom wheels and a different look you have no choice
Old Nov 19, 2013 | 09:26 PM
ChrisWardie's Avatar
ChrisWardie
Ho guys hope you can help. I drive a fiesta mk6 zetec and looking to get some compomotive mo5's 16' but they are et25.. Too small? Opinions?
Thanks
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
youngben
Sep 27, 2015 09:37 PM
timsrs
22
Sep 24, 2015 08:14 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
