whale tales
Old Dec 16, 2004 | 08:04 PM
righthooker's Avatar
righthooker
Default whale tales
i know they are fixed under the little button covers but what is actualy under then screw ,bolt or what .my n/s is a bit wobbly and cold do with a tighten up,but how do the buttons come off
Old Dec 16, 2004 | 09:47 PM
3dr_Mark's Avatar
3dr_Mark
which buttons are you on about
if its the grey ones in the trim, they just push in.
but be carefull getting them out, as they mark very easily and look crap when you put them back in.
you can but a tool to do it with its a bit like a small lever bar that has a slit in it.
if your buttons look like a big screw head then use a 50 pence peice to turn them half a turn and they should pop out.
Old Dec 17, 2004 | 03:48 PM
righthooker
the ones on the spioler ,three each side i got just a screwdriver in there seems a bit like damage
Old Dec 17, 2004 | 05:02 PM
3dr_Mark's Avatar
3dr_Mark
umm do you mean the ones on the out side or on the in side?
Old Dec 17, 2004 | 05:03 PM
3dr_Mark's Avatar
3dr_Mark
oh hang on i will go look at mine
Old Dec 17, 2004 | 05:10 PM
c9sse's Avatar
c9sse
carefully take the covers off
two holes are screws the other is rivet
little metal brackkets under the spoiler what they screw or rivet to.
if the screws dont tightnen it up then you may have to take the spoiler off
and start again
Old Dec 17, 2004 | 05:47 PM
3dr_Mark's Avatar
3dr_Mark
yeah just had a look at mine the best way to remove those covers is with a pick.
but be real carfull as they are painted and you could cause damage to the paint.
anyway once your in it is as c9sse said
Old Dec 17, 2004 | 06:32 PM
righthooker
thanks chaps
3drRich
Sep 13, 2015 07:32 PM
DanRs
Feb 2, 2006 11:36 PM
Leo
Dec 16, 2005 09:14 PM
Tom Baxter
Ford Escort RS Cosworth
11
Dec 11, 2005 03:06 PM
rb5371
May 17, 2005 07:18 PM
