powdercoating and gaskets...
i wanna get my rocker covers/cam covers powder coated (as theyre currently just painted n it looks wank) BUT the rocker covers have integral non-removeable rubber gaskets on them.
im worried that the powdercoating process will kill em...
any thoughts on the matter?
I am interested in this answer too as i am having my inlet manifold and plenum done. will it be better to have both parts done separately then use a new gasket to rejoin?
Jim / Switch - apparantly there is a powder coaters in Basildon who may be able to help. Ill get you the phone number. Im looking for a p.coater as well as i want me cage done!
powder coating requires the over to cure the powder turn it from powder(dust) to paint and the gaskets will not be of any use afterwards same as rubber or plastic cant 100% what temperture but its well over 100oc
there is a top guy in Rainham essex he has a powder coating company, he does all big department store stuff like shelfs and rails etc.. he throws a whole load of my stuff through for next to nothing
if you need anything done and your close im sure he could help.
jim, when i powder coat cam covers i mask the insides, where the gasket goes etc so the under side is not p/c.
i dont know about yours for the V6, does the gasket not come out??
usually the ovens are 180-240 deg C, how hot can the gaskets take?
i have done many zetec covers, and there are plastic clips that hold the plug leads in and they have been fine after heating.
as for shot blasting, that will fuck the gasket
HTH
HTH
HTH
HTH
gasket is NOT removeable...
if you fuk a gasket on one of these engines, you need a whole new rocker cover
and they aint cheap!
been advised to speak to robS about getting em painted
the plenum i'd probably get powdercoated
and they aint cheap!been advised to speak to robS about getting em painted
Just one question, why do you all go for Powder Coating of Engine parts??
Mine are all wet-painted. As are my Brake Calipers. The finish is far nicer and they don't need to go through the high heat level of Powder Coating.
thats true, simply spraying it will be fine, powder coat is more durable tho as its harder and wont scratch as easily, and it wont chip.
i still dont paint the under sides of cam covers tho, just incase the paint were to flake for some reason.
Charging me £25 to powder coat it samco blue
Picking it up tomorrow, i'll let you know how it goes
I agree, Powder Coat is a durable finish, but I am yet to see a Powder Coated Cam Cover that looks ANYWHERE near as nice as a Painted one. I see Powder Coating as a Commercial process for stuff like Garden Furniture etc. Unless you are chucking spanners at your engine, I really don't see a need for it to be that tough. Mines been on for a couple of years now and if it is slightly tatty, its only because its been apart so many times.
powdercoating will be ok in usally, but with you gaskets that are fixed it may cause a problem when there baked, also with engine parts it better to have the parts acid dipped and not sandblasted, i made this mistake and ended up destroying my mates engine becasue the sand had seized the oil pump
well mine are currently pinted and the paint is flaking off and also where it was dirty i tried using GUNK to clean it and it took half the paint off too... the finish on it looks naff
i fogure if it gets powdercoated it'd look nicer and last longer
i couldn't give a shit what mine looks like. as long as it does the job. i figure it's more important to have stuff that works right, before it looks right.
imo jim, get the engine running properly before you piss about with cosmetic stuff.
I've had bits powder coated and don't see anything wrong with the finish when compared to painted parts - mine are gloss black, silver and red and look nice and shiny.
I have to admit that I did the petrol tank in flat black and I was a little disappointed - nothing wrong with the finish, its just not shiny!!!!
jessie_rs
11
Jun 3, 2019 04:57 PM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
