Doors on a saff
Old Jul 30, 2009 | 08:46 AM
MannheimAlex's Avatar
MannheimAlex
Default Doors on a saff
Hi, are the doors of a saff cosworth the same as those from other saffs or are they special. And is there any difference between the doors with power windows and those without them?
Old Jul 30, 2009 | 09:01 AM
james kiely's Avatar
james kiely
doors are the same,no difference .
cheers james
Old Jul 30, 2009 | 09:04 AM
rog's Avatar
rog
Doors are the same, some wiring is different and the handles inside are different between 2WD and late spec 4x4. If your just talking about the actual metal panel i.e. completely bare door excluding bolt on bits, then yes they are all the same.
Old Jul 30, 2009 | 11:56 AM
paulshears's Avatar
paulshears
as Rog says, the inside handle is different
I put doors off a K reg Azura onto my G reg Saph....... put all of my door trimmings back on and the very last screw I tried to put in would'nt go (release lever)
the hole the screw goes in is in a different place on newer doors (about 10mm higher I think)........ had to take all the trim back off to drill a hole in the right place
Think this was only on the front doors
also I had a problem knocking the pin's out of the hinges on the G reg........ but on the K reg they knocked out easy
Rear doors........ little slot for the child lock is in the wrong place
vertical on one & horizontal on the other..... can't remember which way round it was
Old Jul 30, 2009 | 11:59 AM
paulshears's Avatar
paulshears
also was a pretty time consuming job........ my brother who does paint & body repair was helping me & it still took ages
Old Jul 30, 2009 | 01:11 PM
MannheimAlex
Thanks a lot guys! So i will give it a try at the local scrap yard.
chowfornow
14
Jan 5, 2019 09:01 PM
ajamesc
Sep 27, 2015 02:25 PM
mpilk
Sep 27, 2015 09:21 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
