S2 Headgasket Question??
Old Dec 16, 2004 | 10:52 AM
RS-adam's Avatar
RS-adam
Default S2 Headgasket Question??
this is something I've been wondering bout for at while, and now when I had to take the head of, I decided to take some pictures and ask the board
the thing is, that on the headgasket, that I've been using, the holes for the water, isent the same shape in the gasket as in the block... and this i STD RST engine
The gasket on the picture is a original ford gasket
This in on the inlet side:
and this is on the outlet side:
anyone got some answers to this... my thought is, could this be why my car easy run hot??? and If u buy a GRP. A gasket, would this have another shaped around the waters holes??
cheers in advance
Old Dec 16, 2004 | 12:45 PM
220TC's Avatar
220TC
are you sure thats a ford headgasket ? dosent look like it to me
I have used a ford headgasket before and I'm pretty sure the water holes were different to yours.
Dont bother with a group A or felpro, use a genuine ford headgasket or a halls payen one (they are the same but halls payen are a few quid cheaper ) Ford finis number is 1658584 .
Hope this helps, Duncan
Old Dec 16, 2004 | 02:00 PM
adamS2RST's Avatar
adamS2RST
dont look like a ford gasket, could be wrong tho
Old Dec 16, 2004 | 03:36 PM
turbo.jon's Avatar
turbo.jon
nope it aint ford one ive had one like it before bought whole head gaskit set from local car spares shop...did the job till bottom end went
Old Dec 16, 2004 | 04:18 PM
sime73's Avatar
sime73
whats wrong with group a or felpro's
Old Dec 16, 2004 | 05:54 PM
Moonie's Avatar
Moonie
The holes in the gasket are normal, they are designed to control the flow of water throughout the engine/head.
Old Dec 16, 2004 | 06:44 PM
JesseT's Avatar
JesseT
I believe it's to equal the flow around all the cylinders.
Old Dec 17, 2004 | 08:00 AM
220TC's Avatar
220TC
nothing really mate except the felpro is more suited to the 1.9 I believe because of the bore size. A felpro gasket is normally reffered to as a group a
I think cometic are now doing a headgasket for the escorts, not cheap though !! last time I looked I think they were over Ł100
Duncan
Old Dec 18, 2004 | 11:34 PM
RS-adam's Avatar
RS-adam
but WHAT if I cut out the holes in the gasket, so the fit the holes in the block.. would that be a STUPID idea, or could it possible help my problem wit high temps????
just at thought
Old Dec 18, 2004 | 11:42 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
cant help there, but this is a std ford gasket, ready to fit, i had here,
if it helps
regards dave
Old Dec 19, 2004 | 08:55 AM
RS-adam's Avatar
RS-adam
hi dave..
Im also gonna fit a STD ford gasket... and it looks exatly like the gasket I took out of the engine...
Old Dec 22, 2004 | 09:22 PM
gammi0025's Avatar
gammi0025
Whats the max boost you can run with a standard ford head gasket?
has anyone seen them copper gaskets are they any good???
Old Dec 23, 2004 | 03:35 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
std headgasket all the way, gammi u can run more than ure engine will take so
headgasket wont be the limmiting factor.
afaik payen make ford head gaskets. i'll get a pic of a new std payen one i have tommo and put it on.
Old Dec 23, 2004 | 02:13 PM
Moonstone Cossie's Avatar
Moonstone Cossie
Felpro Gasket is only Ł30.00 from Burton Power
Old Dec 23, 2004 | 02:31 PM
vroooom ptssssh
It Wasnt Me!
Why get a felpro when std is best?
Heres a payen one, im SURE payen make ford headgaskets, or atleast the ones for our cars.
Old Dec 23, 2004 | 04:28 PM
220TC's Avatar
220TC
yes, payen make the gaskets for ford. Also if you get them from mike at ferriday there cheaper as well
Old Dec 23, 2004 | 05:01 PM
T28 RST's Avatar
T28 RST
Ok then
Im using a standard ford head gasket on my car after having many problems with felpro gaskets, i also got the block wire ringed to make it even better
Old Dec 29, 2004 | 04:09 PM
white cab's Avatar
white cab
why dont you just go for a copper head gasket to start with 1 you can get alower compresion ratio an 2 they will not blow out. go to http://www.ferriday.co.uk/ they have a range of gaskets to use thay are about 100 quid and i have seen a cortina with a cosworth lump in using one and it runs 10 second 1/4ers
Old Dec 29, 2004 | 04:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Are the above any good?
Old Dec 29, 2004 | 04:46 PM
white cab's Avatar
white cab
well back in the day they were all the rage on the pinto but you do have to have good flat gasket surfaces to avoid oil,water, air leaks i think they do o ring kits too for oil ways but that is extra i assume i has to be good if there is a high powered cortina cosworth that does 10?second 1/4s all day long and it hasnt packed up yet it will be on my list during my engine build
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
