cosworth garret t34,.48 housin,greens,msd chip,actuator,3 bar map sensor,£850,almost
Old Jul 28, 2009 | 08:20 PM
155lee's Avatar
155lee
Default cosworth garret t34,.48 housin,greens,msd chip,actuator,3 bar map sensor,£850,almost
chip now sold.turbo which is a t34 with a .48 exhaust housing,£550,done 1000 easy road miles and is 10 months old,£550.actuator,collins adjustable,£50,greens,10 months old,£100,3 bar map sensor,£40.will sell seperately or do the whole lot for £740 delivered.these parts were running 335bhp atw with an msd stg 3 chip,rs500 style cooler and a mongoose exhaust.thanks,lee
Old Jul 30, 2009 | 02:38 PM
millsey's Avatar
millsey
Default turbo
intrested in the turbo if you still have it avaliable
Old Aug 3, 2009 | 06:56 PM
155lee's Avatar
155lee
Old Aug 4, 2009 | 06:26 AM
Stu @ Claims Care Centre's Avatar
Compensation Specialist
what cams is the chip mapped for?
Old Aug 4, 2009 | 07:03 AM
creator's Avatar
creator
how much for the greens and 3 bar map sensor posted mate?
Old Aug 4, 2009 | 11:27 AM
155lee's Avatar
155lee
standard cams,the chip is sold.
Old Aug 4, 2009 | 11:19 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
I will twll my mate as he is looking for this set up pm me your number Lee
Old Aug 19, 2009 | 12:10 AM
155lee's Avatar
155lee
for sale again!
Old Aug 20, 2009 | 10:03 PM
155lee's Avatar
155lee
Default 2wd sierra cosworth compbrake 4 pot 350mm x 32 mm front brakes
this kit has done 600 miles on my car.never done a track day or been used hard but have been tested on some 'private stages' and they pull the car up time after time no problem.the calipers are red and the bells are a matt gold colour.the rotors are grooved,not drilled so no chance of cracking.comes with all brackets,bolts,washers and wheel spacers which were all necessery to fit to my car.i dont know if they will fit under 17" wheels but they fitted under my 18" mo's no problem.i want £750 + £20 delivery for them.click the link for the kit as i dont have any pics on my work computer and thats where i am till monday.ta,lee
http://compbrake.co.uk/shop/product_...4ac0b9cd6a5ec9
Old Aug 21, 2009 | 12:04 AM
155lee's Avatar
155lee
Default loads of cosworth parts,like new!!!
pair of 2wd front hubs with new ggr bearings and new ford dust caps.powdercoated black.£80
rear hubs and flanges,new ggr bearings and powdercoated black.£70
driveshafts,new ford boots and powdercoated black.£60
ggr group a dump valve.1 year old,looks 100% better than the bailey 1 and sounds better too,£90
alloy crank pulley,burton make.few months old.£55
compbrake adjustable tcas,3 months old,never been on track.£130
reconditioned 2wd steering rack with short input stub.been on car 3 months.perfect working order,£130
leather doorcards,passenger front has lifted under armrest,possibly would stick down but im no retrimmer,rest are perfect,£100
front bumper in smokestone with rs500 style spliter and rs500 vent cut in,professionally done and looks great,new insert moulding,1 bracket has broken on drivers side,cable ties hold it perfectly though.£400
rear bumper in smokestone.cut for a 4" tailpipe so it doesnt vibrate or knock.has 1 hole on each side for mudflaps,£80
rear shelf with hole filled in with wood,trimmed in black leather look vinyl with 6x9 speakers,£60
almost new ford rear diff mount,not rusty and was fitted by me 2000 dry miles ago,rare,£65
fuel tank,all painted in a nice bmw silver,no leaks etc,£50
rear brake compensator,no leaks,painted black,£40
4 working abs sensors,worked perfect on my car,£100
almost new clear ford front indicators,£20
2wd starter motor,perfect working order,£25
4x4 starter motor,untested,£20
2wd v belt alternator,good working order,£30
2wd engine loom,,temp sensor plug has came off apart from that its perfect,£100
ford racing gauges,boost,volts and oil pressure,green backlit with 2wd vent pod,with all wiring and pipework,£150
i still have the immaculate shell which recently had a 3k paintjob,new windscreen,detailed underside,electric sunroof,black dash,private reg,(c11 wth),black dash and black carpet,glass,retrimed roof lining,new ford brake lines,almost new abs pump,block and pressure sensors,engine x member,mint roof gutter strips,bootlid and doors.all in rust free condition.dont know how much im asking,depends on whats left on it.all prices + postage,thanks and check out my other posts for all the other goodies i have,lee
Old Aug 21, 2009 | 06:13 AM
B16's Avatar
B16
Hi Lee
Do you have a postege price for the front hubs.
Paul
Old Aug 21, 2009 | 04:34 PM
capri280's Avatar
capri280
hi lee
any chips or marks on the front clear indicators plus all in postage to me in the north of ireland
eugene
Old Aug 21, 2009 | 04:36 PM
155lee's Avatar
155lee
Originally Posted by B16
Hi Lee
Paul
hi,say £15 for postage as they are quite heavy.
Old Aug 21, 2009 | 04:38 PM
155lee's Avatar
155lee
Originally Posted by capri280
hi lee
eugene
hi,no marks or chips.they were brand new from ford 2 years ago and the car didnt do a lot of miles with them on.say £5 postage as ill wrap them up with plenty of bubble wrap.ta,lee
Old Aug 21, 2009 | 04:43 PM
capri280's Avatar
capri280
i take that the bubble wrap i sent you
Old Aug 21, 2009 | 05:16 PM
155lee's Avatar
155lee
did i buy somthing from you before?
Old Aug 21, 2009 | 08:04 PM
B16's Avatar
B16
Lee
Will take the calipers, how do you want payment. Bank transfer is my preference.
Paul
Old Aug 22, 2009 | 10:28 AM
B16's Avatar
B16
You have PM.
Old Aug 23, 2009 | 05:29 PM
155lee's Avatar
155lee
up!
Old Aug 23, 2009 | 05:30 PM
155lee's Avatar
155lee
up!
155lee's Avatar
155lee
up!
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
costina
18
Aug 25, 2015 06:02 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
