psi for stage 1 mountune chip????
Old Dec 15, 2004 | 10:35 PM
agus RS's Avatar
agus RS
Default psi for stage 1 mountune chip????
hello friends, who psi peak/holds for mountune chip stage 1 for 3 doors cosworth ???
many thanks
Old Dec 16, 2004 | 08:25 AM
JamesH's Avatar
JamesH
15psi tops
Old Dec 16, 2004 | 08:08 PM
agus RS's Avatar
agus RS
tops=holds??
Old Dec 18, 2004 | 07:07 PM
JamesH's Avatar
JamesH
should hold 15psi, check with others too
Old Dec 19, 2004 | 08:38 PM
agus RS's Avatar
agus RS
many thanks
Old Jan 5, 2005 | 10:14 AM
RSCosworth's Avatar
RSCosworth
since the original MAP sensor will not read pressure above 15 psi, your car will run lean above that. the original injectors are also on the limit on 15 psi.
Old Jan 16, 2005 | 12:46 PM
Stu @ M Developments's Avatar
PassionFords Creator
RSCosworth,
This is not true at all. It depends on the top line in the fuel map, the map sensor just tells the ecu which line to access.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
