vw tdi fault 00575 Intake manifold pressure sensor
Old Dec 15, 2004 | 09:03 PM
apples24's Avatar
apples24
Default vw tdi fault 00575 Intake manifold pressure sensor
anyone help?? what and were is this? i presume its not what looks like the charge temp sensor thats at top of engine along the big plastic instake hose from the cooler?
Old Dec 15, 2004 | 09:05 PM
ECU Monitor Enthusiast
MAP SENSOR - dont know where it is though !
Should be a pipe off the intake manifold connected to a small box mounted off the
engine somewhere. (usually has 3 wires connected to it)
Old Dec 15, 2004 | 09:09 PM
apples24's Avatar
apples24
fook ok m8 gotta find out as off to the scrappy tomorrow to get one
Old Dec 15, 2004 | 09:16 PM
EIL132's Avatar
EIL132
Try http://www.onboarddiagnostics.co.uk/
apples24's Avatar
apples24
think im sorted the map is by ecu but theres a hose that runs fromt here to manifold thats prone to corrosion so fingers crossed
Old Dec 15, 2004 | 09:46 PM
markk's Avatar
markk
the tdi doesnt have map , its on mafs , where did you get that code and what car ??
Old Dec 15, 2004 | 09:50 PM
EIL132's Avatar
EIL132
http://www.msi-motor-service.de/ximages/4032.pdf
Old Dec 15, 2004 | 10:57 PM
bunglescott's Avatar
bunglescott
if it is that sensor in the main plastic intake pipe (huge one) make sure you get the right one or take your old one with you .There are three different ones and theres a modified plastic intake pipe as well
scott
Old Dec 15, 2004 | 11:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its commonly the intake pipe clogged with crap as opposed to teh sensor itself, so check it out. As said, thers an uprated one which is essentially just larger bore and less prone to clogging.
Old Dec 16, 2004 | 07:50 AM
apples24's Avatar
apples24
ahh so remove that huge plastic pipe too? flush it out or somin?
Old Dec 16, 2004 | 07:54 AM
apples24's Avatar
apples24
mines a 98 passat 1.9 tdi s by the way
yatta
May 21, 2016 10:31 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Kam B
Sep 24, 2015 10:40 AM
Si B
Sep 12, 2015 06:49 AM
