cvh engine sensor gearbox oil
Old Jul 26, 2009 | 07:39 PM
luxembourgrst's Avatar
luxembourgrst
Default cvh engine sensor gearbox oil
hy i know that there is one picture on the forum where we can see wath sensor fit on our cvh s2 engine on the manifold
thanks
and how we change the gearbox oil when the engine is install in the car
thanks
Old Jul 27, 2009 | 06:13 AM
DazC's Avatar
DazC
i can't help with the picture but there is no oil drain plug in the gear box so it cannot be changed easily.
Old Jul 27, 2009 | 06:35 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
thanks
thanks
there is no sensor on the exaust manifold but there are a few on the inlet you will need to post a pic.
and as said you can not change the gearbox oil only top it up the only way to change it is to pop a drive shaft out you can get mose of it out that way
Old Jul 27, 2009 | 05:05 PM
luxembourgrst
yes i was thinking about the intel manifold sensor
my engine is out the car but fixent on the motor block my drive shaft are out but where i put the new oil in and how much thanks
Old Jul 31, 2009 | 08:13 AM
mark2's Avatar
mark2
hi
you use a suction pump to exstract oil from gearbox
either electric one or hand operated far easier than a drive shaft out which as said above works
mark2
RUBY123
Oct 22, 2023 12:04 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Chas
Sep 21, 2015 08:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
knight19770
Aug 4, 2015 12:36 PM
