Blue smoke
Old Jul 26, 2009 | 10:19 AM
Barry R's Avatar
Barry R
Default Blue smoke
What is it usually mean on a cossie when you have come on boost let off again and then you get a big cloud of blue smoke?
It only does it when you have been on boost.
Is it the turbo seals?
Old Jul 26, 2009 | 12:45 PM
Sounds more like stem seals, but if any amount of miles probably a combo of everything, if it's only then I wouldn't worry.
Mine does it even with new turbo and head, but I know my rings are shagged!!
Old Jul 26, 2009 | 01:20 PM
Barry R's Avatar
Barry R
The bottom end is fresh new everything got a old t34 on it now never smoked before that
just paraniod i think must be turbo
As I say it only smokes when on boost
wont smoke from cold
Old Jul 26, 2009 | 01:23 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
sounds more like the turbo to me. mine would give a puff after boost when i put the foot down again. the rings and stem seals had been done . a new turbo cured it.
Old Jul 26, 2009 | 01:25 PM
Barry R's Avatar
Barry R
Oh well thought so is it ok to keep on to run the engine in or shall I take the act arm off
Old Jul 26, 2009 | 03:53 PM
AndyPen's Avatar
AndyPen
My old T4 was like that Barry - the new one solved it.
Old Jul 26, 2009 | 05:53 PM
col cos1's Avatar
col cos1
rings
Old Jul 26, 2009 | 05:59 PM
Barry R's Avatar
Barry R
Brand new rings mate
I drove it with the waste gate fully open and no smoke as soon as the act is on
again it smokes
Old Jul 26, 2009 | 06:07 PM
cossiedave's Avatar
cossiedave
if you guys new how he rebuilt it you would be all saying its not been built properly ie just thrown together you should of took me up on my offer now you have to do it again more money you ant got
Old Jul 26, 2009 | 06:09 PM
Barry R's Avatar
Barry R
It was buit proper mate by my boss for free
Its the turbo it must be
What do you mean thrown together?
Old Jul 26, 2009 | 06:17 PM
cossiedave's Avatar
cossiedave
lets see how long it last did he hone it out properly ie 45 degres cross hatch
Old Jul 26, 2009 | 06:24 PM
Barry R's Avatar
Barry R
Yes mate it was all done properly hes been building cars for 40 years
Recently built his 1960s v8 mustang thing thats was a physcho stupid power
Old Jul 26, 2009 | 07:24 PM
col cos1's Avatar
col cos1
im still saying rings
Old Jul 26, 2009 | 07:30 PM
fuzzy's Avatar
fuzzy
having seen the comment about it being built for free im now guessing its something more terminal like the rings.
Old Jul 26, 2009 | 08:09 PM
Barry R's Avatar
Barry R
No my boss built the bottom end in return for overtime without pay
I was there the whole time it can only be the turbo i have drove it without any boost and its fine when its boosting its only boosting .5 bar as its running in
Old Jul 27, 2009 | 12:08 PM
silky16v's Avatar
silky16v
Get on That!
make sure you get the dam thing in boost as the rings won't bed in otherwise, mine puff's alittle out after i've given it a boot-full (32psi+)
Its just part of owning a cossie it will use some amount of oil (shouldn't be alot mind but they do use it)
my turbo has been on there 9 yrs so probs due a re-build anyhow
if your in any doubt get the turbo checked and re-sealed
Old Jul 27, 2009 | 12:50 PM
mechanic28's Avatar
mechanic28
Does sound like turbo but even with a new turbo it will still blow out abit of blue/black smoke when giving her some beans!
Old Jul 27, 2009 | 12:52 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
If you fitted new rings are you using a mineral oil to bed them in, if not it will smoke its arse off from now to dooms day.
Steve
Old Jul 27, 2009 | 03:39 PM
Barry R's Avatar
Barry R
Im not using mineral oil to bed them in mate never had before always used £20 a gallon stuff same as a mate of mine and his was fine
Old Jul 27, 2009 | 03:40 PM
Barry R's Avatar
Barry R
I can drive the car for hours off boost with no smoke but as soon as it sees some it will smoke
Old Jul 27, 2009 | 04:46 PM
silky16v's Avatar
silky16v
Get on That!
if you've pussy footed it about while bedding it in and not used a cheap nasty running in oil i doubt your rings will have bedded correctly and as soon as its seeing boost and backing off again its pulling past the rings and out the exhaust, take the plugs out after you've given it a foot full and post a picture up if they look all oily your engine is burning oil if they are all clean and have the right colour to them i'd suspect your turbo seals
Old Jul 27, 2009 | 04:54 PM
Barry R's Avatar
Barry R
Its only done 200 miles so far so shall I give it a bit of shit or not
Old Jul 27, 2009 | 08:20 PM
silky16v's Avatar
silky16v
Get on That!
well 75%+ of the running is done already get the standard boost running threw i and change the oil for some normal high milage mineral stuff do another 300 miles but use the car and the full rev range but don't thrash it then drop the oil and use some correct synthetic oil and get the cars boost and fueling set and take it from there.
if you done 200 miles driving like a faggot the rings won't have bedded in
mine get 10 mins with mineral oil holding revs at 1500rpm - 3000 rpm
drop the oil and filter more mineral oil then 50 miles of driving around on boost using the rev's but no thrashing then back for another oil and filter change this time some semi-synthetic rubbish and then 200 miles being used on-boost all rev's but no labouring the engine, then back for a final oil & filter change on 15w-50 full-synthetic and straight for a check up for boost & fueling and then driven hard so in total engine has done 300 miles+ then used hard it will of course still loosen up with more miles but out of 10+ engines i've built 1 has never failed or burnt oil.
it goes without saying that it get a full nut and bolt check after the 1st 50 miles but if you have done the job right you shouldn't have any issues
Old Jul 27, 2009 | 08:44 PM
Barry R's Avatar
Barry R
Its been given a bit of stick first 30 miles was upto 4k its been to 6.5k a few times
Gonna drive it like you said then
Old Jul 27, 2009 | 08:50 PM
AndyPen's Avatar
AndyPen
Mineral oil is th stuff to use though Barry mate
Old Jul 27, 2009 | 09:17 PM
Barry R's Avatar
Barry R
Gonna buy some as soon as I can then Shall I not drive the car untill I get some
Old Jul 28, 2009 | 05:51 AM
MARCOSWORTH's Avatar
MARCOSWORTH
I done mine on mineral oil and boosting like normal but not for long periods, only shorts like 5 secs, changed from mineral to Silkolene Pro S 10w50 after 800 miles
I've done now 15000 miles with no smoke
Old Jul 28, 2009 | 06:40 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by silky16v
LOL Silky "I won't have another Cossie" heh. I came up and bought your hubs a while back. So the Jap has gone and back to Cossie goodness, nice one
Old Jul 29, 2009 | 12:01 PM
silky16v's Avatar
silky16v
Get on That!
didn't intend on going back my mate wrote my Evo MR off and so i bought another cossie until/eventually he pays me back
Old Jul 29, 2009 | 04:03 PM
Barry R's Avatar
Barry R
Had another look at turbo and there is a a oily film in the compressor housing and a bit of in and out play
Old Jul 31, 2009 | 04:41 PM
Barry R's Avatar
Barry R
Right then ive lost boost now
it goes upto .06 bar then drops too .04 then .03 any ideas
Done the normal checks no air leaks or nout like it
Old Jul 31, 2009 | 05:05 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
your turbo is fooked for starters
Old Jul 31, 2009 | 05:14 PM
Barry R's Avatar
Barry R
yhpm
Old Jul 31, 2009 | 09:53 PM
bigchez's Avatar
bigchez
Turbo pal. mine started like that, then sounded like a siren, then died
Old Jul 31, 2009 | 10:03 PM
forevaford's Avatar
forevaford
32 psi, turbo lasted 9 yrs??
Old Aug 1, 2009 | 12:38 PM
marco polo's Avatar
marco polo
defo not.................. it's 100% the turbo oil seals are fooked
Old Aug 1, 2009 | 01:02 PM
Barry R's Avatar
Barry R
Good
Who does every 1 use to rebuild them?
Old Aug 4, 2009 | 07:43 PM
silky16v's Avatar
silky16v
Get on That!
nah only been running that boost for last 3000 miles but turbo is 9yrs old according to the receipt but its only done less than 10000 miles since then
Old Aug 4, 2009 | 07:44 PM
silky16v's Avatar
silky16v
Get on That!
Good
try Tony@Turbosystems or Vince@CRturbos
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
