Cometic water pump gasket failure
Old Jul 25, 2009 | 03:54 PM
RS Juto's Avatar
RS Juto
Default Cometic water pump gasket failure
Anyone ever had one of these fail. Finally got the car set up to day after running it back in and went for a spin. Suddenly steam everywhere, turned out to be the cometic water pump gasket has gone porous and water every where
Great, made a right mess of the engine bay, got to get the autosol out again.
Old Jul 25, 2009 | 04:53 PM
Sonic Boom's Avatar
Sonic Boom
I've had 2 water pump gasket failers, the block side was completly flat as was the water pump so I just made my own gasket out of really thick gasket paper and put a small smear of gasket sealer on for good measure and i've never had a problem since.
Rich
Old Jul 25, 2009 | 06:09 PM
RS Juto's Avatar
RS Juto
Originally Posted by Sonic Boom
I've a had 2 water pump gasket failers, the block side was completly flat as was the water pump so I just made my own gasket out of really thick gasket paper and put a small smear of gasket sealer on for good measure and i've never had a problem since.
Rich
Sounds like a plan, Cheers Rich
Old Jul 25, 2009 | 11:55 PM
rs2klee's Avatar
rs2klee
K***LMT
i have just fitted one of them as just put a new thermostat in.. ill keep eye on it now!
Old Jul 26, 2009 | 09:08 AM
My cometic has been on and off at least 10 times with testing different stats, not a drop has leaked.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
