How to re-fit a 3 door loom?
I have got the loom back in the car now, the bits of loom that go through the bulkhead to the engine bay have been put through, i have clipped the interior loom up onto the bulkhead where it belongs and routed the parts of the loom that go to the back of the car as they should be.
Over on the passenger side there are two electronic control boxes of some sort with a large multiplug going to each one, (i dont know what there for but they are clearly some sort of E.C.U's), i am having trouble trying to work out where they should be mounted, they are both attached to a flat aluminium plate, the wires coming out of these E.C.U's have a smaller aluminium bracket cable tied to them with 2 plain holes at one end and 2 threaded holes at the other end and i assume these two plates should mount onto something to hold the E.C.U's securely in place. There is a large aluminium bracket bolted through the bulkhead but i believe that is for the dash to screw onto?? Also just underneath the inner bulkhead above the passenger footwell there is a smaller bracket, i am wondering if they should somehow be fixed to this?
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark V8
Sep 13, 2015 09:34 AM
