What BHP is my car (roughly)
Old Jul 21, 2009 | 03:15 PM
Cozzy111's Avatar
Cozzy111
Default What BHP is my car (roughly)
Below is the spec of my 3 door cossy that i've just bought, what sort of BHP and Torque should i be expecting from this engine, i know its alot down to the mapping but i was just wanting your thoughts!!
Engine wast done a couple of years ago and has only covered about 2500 miles,
Spec
Engine rebuild with new 200 block, low compression mahle pistons with valve cuts, shot pinned rods, light weight pulleys, Small port head with bd14 outlet cams with iski double valve springs, Group A Head gasket, new T34/63 exhaust 247 shaft turbo with – 31, Reconditioned T5 Gear Box with organic clutch, Water injection, Grey Injectors, P8 ECU with pectel board and chip to match, boost is set at 27 PSI, 3 bar Map, RS 500 Intercooler, Alloy Radiator, Running a coil pack with motorsport HT leads, new 044 fuel pump, Group A K & N air filter, Mongoose exhaust.
Thanks Guys
Old Jul 21, 2009 | 03:40 PM
Captain500rs's Avatar
Captain500rs
I'd say between 360-400 mark
Old Jul 21, 2009 | 04:31 PM
siscossie's Avatar
siscossie
3-door moonstone
I`d say the same maybe a bit more sounds like a good start
Old Jul 21, 2009 | 05:20 PM
STUCOS's Avatar
STUCOS
Is it live mapped or an off the shelf chip,if it,s off the shelf i would go with 375,get it on the rollers
cheeRS stu
Old Jul 21, 2009 | 05:40 PM
Cozzy111's Avatar
Cozzy111
Think it was map was done by harvey gibbs, not sure tho!
Gonna get it mapped soon
Old Jul 21, 2009 | 08:44 PM
LHD220Turbo's Avatar
LHD220Turbo
power will be determined by what boost pressure you run
at 27psi i'd say 360-370hp, but if live mapped at around 32 psi, should see circa 400
Old Jul 22, 2009 | 05:02 PM
AndyPen's Avatar
AndyPen
I run an rs500 with a similar set up but the head is ported and the turbo is obviously a T4. I get 437bhp at the rear wheels so you could well be looking at up to 400ish - sounds good
mgtkr1
107
Dec 6, 2016 04:23 PM
biggiejody
Insurance
Sep 2, 2015 12:04 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
knight19770
Aug 4, 2015 12:36 PM
