Fitting st170 head, advice needed!
I am in the process of changing from my zvh to full zetec turbo, I have a spare silver top 2.0 from a mondeo and a spare st170 head. Am i able to just bolt on the st head to the silver top bottom end? something comes to mind that the belt pattern is different due to the water pump, is this correct and if so is there a way around it?
Also are there any benifits to using the st head to achieve 300bhp or am i just best using the original head. If the st head will fit then i would be looking at running the vvt. Is there any benifits to using the vvt or is it just more trouble then its worth.
If any one has any advice or experiences to through my way it would be a great help. cheers adam
Aparently the ST170 bolts straight onto a 2.0 silver top.
http://www.turbosport.co.uk/showthread.php?p=1553546
cheers for the reply,I thought that the head would bolt on just wasnt to sure. it says "When using a silvertop block you need to play with belt tensioner arrangement" any idea of what needs to be done, i have heard that this might need to be done but unsure on how!
well i got a full 2.0 silver top engine to do the conversion with, already got the steal rods to suit so will be using that, So will the standard zetec head be ok for 300 bhp then.
a black top head will do 350 standard think the silver top is only good for about 270 both need up rated valve springs
big_Rad
Sep 15, 2017 09:36 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
