Fitting RS1600i front anti-roll bar to S2 ???????
Old Jul 18, 2009 | 07:11 PM
Sideways Si's Avatar
Sideways Si
Default Fitting RS1600i front anti-roll bar to S2 ???????
I am thinking all gearboxes in the S2 were mounted with a steel front to back suport bracket ????????????????
The RS1600i and S1's gearboxes were mounted differently can anyone confirm ???????????????????
If i'm right fitting a RS1600i front roll bar set up to a S2 would just mean using the box from either a RS16i or S1 ??????????????????
Thanks in advance
Old Jul 18, 2009 | 08:17 PM
Ford RS Enthusiast's Avatar
Ford RS Enthusiast
Power
yes or just use a mk3 casing with mk4 internals so then it wont effect your gearing
Old Jul 18, 2009 | 11:12 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
its not a hard job to fit, ive done it to mine, u have to put some holes in the chassis for the bolts, u MUST fit inserts inside the chassis, so when u do the bolts up, it doesnt bend the chassis
Wilsfoci
15
Mar 30, 2016 10:26 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Graceland
Jul 31, 2015 10:34 AM
