What products do I need.
right assuming that I dont own any car cleaning products, what do I need?
please bear in mind that I dont have power in my garage so everything will need to bo manually applied
thanks
thanks
good shampoo, any megs will do, clay and lube, try dodo juice lime prime and 1 of there waxes, megs wash mitt and microfibres, you should get a very good finish with that lot.
craig
craig
lots to be done by hand.
meguiars gold class shampoo,2x meguiars wash mitt(microfibre or lambswool 1 for body 1 for wheels)1 or 2 water magnets,clay kit,meguiars swirl x or stage 1 paint cleaner,meguiars #7 show car glaze or stage 2 deepening polish,meguiars nxt gen tech wax 2.0 or i use meguiars hi tech yellow wax,gold class trim detailer,high gloss endurance tyre gel,smartwax rimwax,an assortment of good quality microfibre cloths and applicator pads
that should do you for a top finish with out power. always did for me
for hand use i would use the autoglmy range if its on the car in your sig? super resin with a coat of egp after or if your using wax p21s.
blackhole(eventho its intended for darker cars) would work well on that coulour and give the paint more wetness.
as said above the megs range is piss easy to use.
personall the poorboys products get the thumbs up from me..oh and twellsie a new one on the list is the jeffs werkstatt range,iv been using it and well impressed,the ease of use aswell as the protection it offers(espescially if your a lazy barsteward)
it would have some good results on the colour of your m5
https://passionford.com/forum/concou...ent-fords.html
Werkstat Acrylic all the way - simply the best protective system for light coloured finishes we have ever used. Also dead easy to use too.
Assuming it's for the silver BMW in your siggie, then our thoughts about what to use and why by hand are summarised neatly in this thread, along with example pictures...
also, what do you do about stone chips? (as the front bumper has got quite a few, do you try to avoid them, wex them, polish them?
the werkstatt acrylic kit is around 45 pound,u get the prime,jet and glos and some cloths.
i have topped up mine with the acryclic jett about 12layers and the finish is the best its ever been!!
and the polished bliss boys will usually get out to you within 2 days.
This is an awesome kit, i was trully blown away with the results, my mother even commented that she thought the car looked brand new again and that the white was now blinding in the sun.
A product i will definatly recommend.
http://www.polishedbliss.co.uk/acata...-kit-kits.html
To order, give us a call on 0845 4540017 or buy online using the above link. The good thing with Werkstat is you don't have to avoid stone chips, as the products will not fill them with a load of mess - just work over the top of them and they will then be sealed in, preventing corrosion (of course, you can always touch them in first if you like).
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
