takes long to start????
Old Jul 15, 2009 | 07:26 PM
ricky_2006's Avatar
ricky_2006
Default takes long to start????
as in title. my escort s2.
seems to take long time to crank over. starts up every morning but takes slightly longer than should.
cold start switch is out.
could it be something like fuel pump relay???????? or something like that
any suggestions.
Old Jul 15, 2009 | 08:13 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could be a number of things worn plugs/leads,starter,bad earths there the easy things to check. Can't see it being anything to do with the fuel pump relay as they usually go and thats it you cant start the car.
Old Jul 17, 2009 | 08:43 AM
Marts's Avatar
Marts
how long is "slightly longer than it should?"
Mine used to take a while to key over, turned out to be a faulty metering unit. Swapped it over and now starts bang on key
As said tho, could be a list of things. plugs, leads, dizzy mechanism, even a part-drained battery not giving enough ummmph to the starter, weak connection at fuel pump blah blah blah............... all easily looked at and sorted tho
Old Jul 17, 2009 | 09:27 AM
cj_rst's Avatar
cj_rst
S2 RST
Mine's got the same, all of the ignition system's been renewed and my fuel pump definitely primes. Is there any way to tell if it's the metering head apart from swapping it over?
Old Jul 17, 2009 | 01:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Try leaning and enrichening the idle mixture, chances are it's just a bit to much one way or the other.
Old Jul 18, 2009 | 08:57 AM
JesseT's Avatar
JesseT
Most commonly it's leaky injectors,
especially if it starts one cylinder at a time.
Toe Knee
Aug 23, 2015 08:31 AM
Sultzi
12
Aug 16, 2015 01:08 PM
Billy_RS
Aug 3, 2015 08:43 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
ginger1979
Jul 31, 2015 09:56 PM
