Where can I get longer exhaust manifold studs from? **Got Some**
When I fitting the tubular manifold and T66 I ended up putting 5mm Stainless Steel spacers in for the Turbo to clear the head.
But now the studs are to short, does anyone know where I can get some longer ones from? Ideally somewhere in Birmingham/Solihull so I can go and pick them up tomorrow, don't really mind to much if I have to order them and get them posted.
Cheers Rich
Cheers Rich
For anyone that cares if you after a set of longer exhaust manifold studs in M8 x 1.25 go to BMW and ask for a set of studs and nuts for a BMW E28 528i they are perfect for the job about 10mm longer than standard cossie ones plus but still have good length that goes into the head (which you don't get on many studs) Plus 16 Nuts and 16 Studs only came to Ł21.78 from Sytner BMW in Solihull.
Rich
Rich
DavidK
Sep 27, 2015 02:55 PM
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
