gear change is like stirring soup
Old Jul 13, 2009 | 09:48 PM
acecraig's Avatar
acecraig
craig89
Question gear change is like stirring soup
hi my s2 gear change is slack and has loads of free play in it im told that that is a common problem but can be fixed i had a look on ebay and found a bush and spring kit
ebay number 380129608624
is this the correct thing for the job and is it fairly straight forward to fit any tips
cheers for help, craig
Old Jul 13, 2009 | 10:08 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
it should be striaght forward if you have a decent ramp and a bit of mechanical knowledge
Old Jul 13, 2009 | 10:27 PM
morph's Avatar
morph
dont forget this kit will not fix the worn bushings on the selector rods that are one of the main causes for poor gear change.
Old Jul 14, 2009 | 08:05 AM
NUTS RuS's Avatar
NUTS RuS
See this simple to follow guide to sort out the problem
http://www.zetecinside.com/xr2/gearbox.shtml#linkage
Old Jul 14, 2009 | 08:47 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The standard linkage is still available from Ford AFAIK and is only around £30.
Old Jul 14, 2009 | 09:30 AM
A10SAP's Avatar
A10SAP
i got a b&m quickshift, but it was still sloppy when i got the car, so i had a look and all the bolts holding it on was loose and the bush on the selector link going to the gear box was proper loose so i got the pin out and put a nut and bolt with washers on, and thats done the trick for now
Old Jul 14, 2009 | 09:32 AM
morph's Avatar
morph
yes this is the easy fix but it will come loose and go again.
Old Jul 14, 2009 | 09:33 AM
morph's Avatar
morph
tried getting these and they have to be ordered and no eta and they are £34 each selector.
Old Jul 14, 2009 | 09:35 AM
A10SAP's Avatar
A10SAP
with a locking nut on?
Old Jul 14, 2009 | 09:57 AM
morph's Avatar
morph
maybe not with a locking nut but mine still wasn't right even with a bolt and nut configuration.
Old Jul 14, 2009 | 10:08 AM
Antti O's Avatar
Antti O
Hi!
Linkage only? not the whole selector?
I believe i have selector bushings or mechanism worn.
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
marky_g
Sep 12, 2015 04:26 PM
Adam Graham
Sep 6, 2015 06:04 AM
