brake lights
hi, does anyone know why my brake lights have stopped working? (on a 2wd saff cossie) i have checked the bulbs, gave the connectors a clean in the cluster, checked the switch is still connected on brake pedal, but nothing the lights are on on the display thingy in the center of the dash which used to go off once the pedal is pressed. any help please
Me Cossie Runs Atlast!!!!
cheers guys. managed to sort it. it was the connector on the top of the master cylinder where the fluid cap is,it had come loose a bit, pushed it on propper and all is good
Dr. Ickxs
Sep 15, 2015 10:15 PM
