Putting an estate exhaust onto a sapph cossie
Old Jul 10, 2009 | 11:12 PM
nzcossie's Avatar
nzcossie
Default Putting an estate exhaust onto a sapph cossie
A bit unusual I know! but here in NZ someone is selling a exhaust which came off a cosworth powered sierra estate. As my exhaustr has more holes than swiss cheese, will it work?
http://www.trademe.co.nz/Browse/List...x?id=228603752
Old Jul 11, 2009 | 09:10 AM
Look up the length of the estate cars versus the others on the net, I think it will fit no probs, I had a escort van exhaust on my mk4 escort hatch only difference was van only 1 box instead of 2, can you not ask him to measure it(exhaust) and you measure your car exhaust.
Old Jul 11, 2009 | 02:44 PM
martysmartie's Avatar
martysmartie
I have always found the lenghts to be inaccurate
Estate is supposidly 4521MM and saph is 4467MM but Cosworth is 4495MM although both are the same.
I would think the two exhausts are diffrent though.
Martin
Old Jul 11, 2009 | 07:52 PM
155lee's Avatar
155lee
The lengths are bumper to bumper,the estate uses slightly different suspension but i think the exhaust route is the same.as long as it came from a cosworth originally and has not been cut to suit it will fit.
Old Jul 11, 2009 | 10:10 PM
nzcossie's Avatar
nzcossie
Thanks guys, I'm going to go and check it out. The only thing is that the exhaust I have on is the original one with 3 mufflers, looks nothing like this one
Old Jul 12, 2009 | 10:39 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the suspension going from saph/hatch to estate would be the major problem here but going the other way it'll be fine
you may need to shorten it a little though as the cenre sections are 4 inches longer to make up for the extrnded rear bit of the car, even though the wheelbase is the same
Kyle Langford
27
Aug 5, 2019 07:54 PM
Karl 3dr
102
Oct 14, 2016 08:17 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
pegaz
11
Aug 9, 2015 06:40 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
